kyrbz
Awhile back I was thrilled to find a vintage Malm fireplace in a thrift store for $79. You can still buy them new for $3,700. It's in good shape, no dents with the screen. I need to clean it up and give it a repaint, but it should look great after a little TLC. It's the perfect fireplace for a mid century modern/brutalist renovation I'm working on.
When I was framing the roof of where this fireplace is going, I hadn't really decided on the exact placement of the fireplace, but figured I would be able to go between the joist with the chimney. Around the time when the metal roof was getting ready to be done, I needed to make a decision of the chimney/fireplace placement. Naturally where it needed to be was right dead center on a roof joist.
Time to do a little surgery on the roof joist. I extracted the section of joist mostly with a multi tool and a straight edge jig I made to get a clean straight cut. While I was removing and boxing in the chimney area I used a 2x with clamps to support the joist I was working on.
Next I took 2x6's and attached plywood flanges on each end. They rest on the flange of the I-joist and are what will support the chimney box. They give me the ability to adjust from the left to right.
A cardboard mock-up of the outer chimney box. The 2x's on the side of the cardboard mock-up represent the angle bracket that are attached to the sides of the real chimney box. The angle brackets attached to the chimney box sit on top of the 2x6's and allow adjustment forward and back. The flanged 2x6's and the angle brackets combined allow me full adjustment last and right, forward and back. Maybe not real evident in pic, but the top of the SS chimney box was cut to match the angle of the roof pitch.
More coming...........
