Chin up bar from the rafters?
RumRiver5.0
River Bend
Hey everyone, I'm looking to help myself out a bit as I don't have much time just yet for the gym. There isn't any secure place in the house for me to mount a chin up contraption so I am looking to hang it from the 7' rafters in the garage. My plan for the bar is to either get something premade or adapt something with my welder and attach it to the rafters. I also think the rafters are pretty weak and will need to be sistered in that area for this project at the very least. If anyone has any ideas on what I can do, materials I can use or adapt, I would really appreciate it.
R
RumRiver5.0
River Bend
If your ceiling is open, i would consider using the joists to support my weight. I would spread the load across at least two joists and make sure that you static test the bar before you hang any live weight rom it.
What I am considering is running full length 2x4s with clips staggered and bolting through them the bar mount.
75gmck25
Alexandria, VA
I ran a 2x4 across the garage ceiling so it spanned two joists. Then I screwed a vertical 2x4 on each end with long deck screws so the verticals hung straight down. For the bar I used standard iron water pipe with round threaded fittings on each end (3 screws in each) and mounted the pipe between the ends of the vertical 2x4's. It held up for a lot of years of use.
Blueshound_GJ
This is Garage Journal, people. OP will need to start with a full-polish 1" titanium bar, and somehow get hold of a cnc machine to make custom brackets. Then, the joists will need to be reinforced with hurricane brackets (to say nothing of the sistering, already mentioned). He will need custom lighting and wiring (don't forget to pull a permit, and hire a licensed electrician). Finally, the garage floor will need to be lowered 3.62" in order to provide full extension during the "hanging" phase of the exercise. Be sure to reinforce the slab, and then the epoxy coat to protect from random drops of sweat. 💪😁👍
mike93lx
Richmond, VA
ZRX61
Solar Blight Valley, SoCal
Wow, that is fantastic! I may just do this. I love dips. I just don't know about the strength of the studs in my wobbly attached garage.
The issue is the part that screws to the wall doesn't appear to be 16in/oc.. so then ya have to fabricate something to go between the wall bracket & the studs.. Chunk of 1/4in steel plate ought to do it
usmc_noma
virginia
I used 1" steel pipe connected in a U shape with flanges at the end. I connected the flanges to 2x4s that spanned across three ceiling joists. It has held me up doing the Murphy twice among other pull up related exercises. Currently I have 4 bikes that have been hanging from it for months.
Squankum
Southeast
Some hazy old pics from the older days of my "Underground Lair" thread.
- 2" antenna mast (go bigger on diameter, it builds grip) (recent browsing has reminded me that stores don't carry antenna - mast anymore, black iron pipe would be fine, too)
- "plates" made out of plywood, hole saw
- carriage bolts through the floor joists but nails or screws would be fine
I put the pipe right up against the bottom of the joists because I need the bar to be high. Cloth "trainer's tape" for grip and also prevents pipe from slipping one way or the other. (It really doesn't want to slip.)
Screenshot 2022-11-25 at 1.58.51 AM.pngScreenshot 2022-11-25 at 1.59.40 AM.png
jrsavoie
North east Illinois
Better be position conscious or you'll knock your noodle.
That can be harder doing one handers
Squankum
Southeast
I'm conscious for every bit of it! I can't crank them out, that's for sure.
It's not a perfect bar -- room for head isn't great, and I don't get a full hang, either. But it's better than no bar.
jrsavoie
North east Illinois
I'm conscious for evert bit of it! I can't crank them out, that's for sure.
That's why mine ended up in the stairwell going to the basement. I could get full hang and had plenty of head clearance.
I would start with 10 finger tip pullups on the headset on the way downstairs from the bedroom.
ordpete944
Polk county, Central Florida
way to turn a molehill into a mountain, OP
There's a wide variety of chin-up bars available which will hang from your door jambs. Slip it into place, use it, take it down put it behind the door. $20.
And there are tons of YouTube videos of these flimsy pieces of tin collapsing under the user's weight and them crashing to the floor. They are quite amusing. Don't forget to video it!
CraigStu
Blacksburg, Va
So when you guys do chinups your feet are not hanging below you? If my bar would have fallen down I would have dropped maybe 15 inches and landed on my feet. milkovich's bar might be weak w/ just one deck screw but 2 deck screws would hold it. A 200# guy is only putting 100# on each bar hanger.
mike93lx
Richmond, VA
Depends on how high the bar is. Not many people can hang from something around door frame height without bending their knees. Also, if you can hang straight legged, it means you either have to jump up to the bar or use something to climb up
R
RumRiver5.0
River Bend
I need full hang. I hate to say it but my stronger days are behind me. Lower back issues but yes, pull ups and chins. If I'm below 200 that probably means I'm dead.
msharley
Central Pennsylvania
You want 1-1/4" black iron pipe (right diameter for full grip)
I would drill two 2X6's with 1-1/2" holes. (1-1/4" if using 1" pipe)
Secure the 2x6's to your joists with 5/16" x 3" SPAX screws....
Thread both ends of 1-1/4" pipe (1" if you have stubby fangers)....
Slide pipe into 2x6's . Install caps on pipe.
There you have it. Sturdy chin up bar for $20! :bounce:
mpire
Florida
The shower curtain rods in my school dormitory were on 3/4 inch pipe going from stall to stall. It was more than enough for us to do pull ups.
It was just a bar, some 90 degree ends, and some screw on end flanges
Granted the shower walls were block, but this could hold two of you.
I also use these to hang wheels on my garage walls.
That being said, not sure how jerky you are, but we did notice some lateral forces from having a heavy punching bag hanging from the garage rafters. My grandfather ended up reinforcing it with cross bracing for the side to side movement.
Walkers
Cave Creek Az
It never ceases to amaze me how foolish some of y’all are. This is an excellent opportunity for the OP to get a forklift or front loader tractor in order to have something to do pull ups from at the right height, and adjustable. Either that or build a detached shop with a proper place for a pull up bar (Right next to the mini fridge).
mike93lx
Richmond, VA
I keep saying it.
A telehandler would solve this problem
