chip broadcast - wolverine
dankeenan
I am breaking up my floor into 3 section (24' x 28'), I put the bondtite down today. I am putting the epoxy down tomorrow with chips. Can I put down all the epoxy then broadcast the chips all at one time, or do I need to put the chips down after each section of epoxy. It took me about 10 to 15 minutes per section to spread the bondtite. So in theory, my first section of epoxy will be 45 minutes old when I am totally done and ready to broadcast.
AlphaGarage
Every Garage, AnyTown, USA
Performance-wise you could go ahead an put down the 3 sections, then broadcast DecoFlakes in one final sweep Assuming the 45 mint limit the LiquaTile should still be wet enough to adhere to the falling flakes. But appearance-wise there is a chance that there might be a noticeable difference between the first and last sections.
If you broadcast immediately after back rolling the epoxy, of course, is still quite wet, the falling flakes setle in with many sinking almost to grade level. As the epoxy cures later broadcast flakes will tend to rest more on the surface above grade.
The difference may be slight enough to not be discernible, but if you want to eliminate that possibility spread the flakes immediately after back rolling.
Either way take a few minutes beforehand to practice spreading the flakes, and toss smaller rather than larger hand fulls, you can always toss down more, but it's impossible to undo an area with too heavy of a broadcast.
