Kielbasavw
I have a lincoln weld pak 180hd, some how the gun vanished during a "remodel" of the shop. I am a big fan of the magnum 100l that it came with. It's small light weight and comfortable. Trying to find factory magnum 100l is proving to be hard since alot of aftermarket companies are using the same name.
Also what I came up with is the 100l is only rated up to 100 amps. And the 180hd is 180amps. Do they make the same gun for higher amps, and preferably a longer cable. 12-15ft?
If not is there a comparable gun that uses same parts like tips and what not I mainly use .025 wire and since I have a 140hd at home that uses the exact same stuff I'd like to keep it that way. Thanks
