Craig Balzer
Sorry this is so long but I tried to provide a lot of inform in my initial posting.
Bottom Line up Front: I am looking for a floor covering that will stand up to near-daily, moderate usage; is UV resistant; is highly reflective; looks amazing with a glossy, smooth shine; can be applied by me; and is cost effective (yeah – try to quantify that objective). I have narrowed down my search to three candidates (I think). I will most likely wait until spring of 2020 to apply it.
Target Building. A newly built, pole barn with a 4” slab over in-floor heat in Colorado Springs that will be used for car restoration and maintenance. The structure is essentially two attached rectangles: the main hobby shop is 48 feet wide and 36 feet deep with 14’ walls. There is an attached 24’x24’ (with 10’ walls) for storage and light usage. These total 2,304 square feet. Details of the structure/build are in this thread: https://www.garagejournal.com/forum/showthread.php?t=432775&
I am considering (A) paint / sealers, (B) epoxy, and (C) tiles.
(A) In my opinion, paint and sealers don’t have the durability. Further, sealers would be over a floor that I feel is too dark to reflect very much light. I realize concrete will continue to cure (and lighten) over time, but once a sealer is applied, the color is fixed.
(B) Epoxy is my preferred covering (right now) – I can be convinced otherwise (hence this posting)
(C) Tiles: I am not a fan of plastic tiles that snap together. Durability is not there; ease of use (moving heavy items across the floor) and dealing with spilled fluids is problematic, and – for all of that – is expensive. I have researched porcelain tiles with a PEI of 4 or more; timing that purchase with a sale or promotion is about the only way to get descent price. When you factor in the cost and materials for installation makes this option - - - prohibitive.
So – unless I am convinced otherwise – epoxy it is. I had a pro apply epoxy my attached 3-car garage in 2017 and am familiar with the prep required and application process. I was told it was 100% solids but has not held up to even light usage and within a few months I had a few chips/scratches in the epoxy. So this epoxy needs to be stronger.
The three candidates (which I believe are all 100% solids) I am considering– in no particular order – are
1. Sherwin Williams’ ArmorSeal 1000 HS Epoxy
2. Armorpoxy’s Armorclad Master Kit
3. LegacyInductrial’s NOHR-S® Polyurea Coating Garage Kit
My problem is while I know enough about epoxy to be dangerous and ask some fairly good questions, I don’t know enough to parse the answers to ultimately make my decision (for example is polyurea a type of epoxy?). This is compounded with the fact that while options 2 and 3 above list the price of their kits on-line, opt 1 doesn’t. (Yeah, I can call SW, but then I circle back to how dangerous my knowledge base is).
I note with appreciation that Armorpoxy offers a 15% discount to Garage Journal members. I served 27+ in the US Army so Armorpoxy or other source may factor in another discount. And, I am 66 -- -- hint hint: senior citizen discount??
I know no one here will have experience with all three epoxy options, but some may have secondhand experience of two of them they could share. I am also anxious for the Armorpoxy and LegacyInductrial reps to chime in with an unbiased pro/con comparison of their products (I have never seen a Sherwin Williams rep here). I am not interested in company propaganda or a sales pitch; I am looking for a straight-forward, fair comparison/analysis.
I am using a planning figure of ~$3/square foot which equates to a budget of $7,000 but I am willing to higher for a quality product.
TIA – Craig in Colorado
