rattle_snake
I have an Evolution Rage2 chop saw that is having motor issues. The motor will turn but brushes arc considerably. Speed and torque are very low. If loaded (cutting) it will trip 20A breaker. Does not trip GCFI, so no current is going to GND.
I disassembled saw and visually inspected everything. Don't see anything odd. I'm assuming this is a compensated A/C commutator type motor. The commutator on the armature is clean. I measure the resistance of the stator from plug to brush holder with switch ‘on’ at 0.3ohms which seems OK and both sides are the same. I’m assuming that the armature is a series type. I get <0.1 ohm between each commutator bar. When measuring 180* across, I see a cumulative resistance of about 0.2 ohm. I do not see any shorts to the armature shaft (which should trip GFCI).
So I haven’t found anything wrong, but obviously something is. What to check next? Would a single broken coil winding do this?
I can’t just toss a $300 saw in the trash or throw parts at it without understanding what is going on. I have a backup 14” HF abrasive chop saw but I almost can’t bear the thought of going back to that turd.
SOLVED: shorted armature, replaced, fixed
