Robert Haas
- Joined
- Sep 30, 2010
- Messages
- 1,749
Finished it. Cold saw work station
I have been lifting my chop saw up on to benches and saw horses for 30 years, I keep threatening to build a place for it but never really liked the designs most folk have come up with. The problem with these type of saws is the saw must be able to turn to make angle cuts. So I have been hunting around for a heavy duty low profile large diam. bearing. Sort of a lazy Susan on steroids. I finally found one a few years ago and tossed it up on the bench for that time when I get around to build this dang stand.
So a good friend told me he had a Sun engine diagnostic station he was tired of moving around. These things are built out of pretty decent steel and has nice big heavy duty casters with locks.. Perfect.
All parts are in place, and I just bought a new German Fein Slugger 14" cold saw.
So with no plans other then it had to be up and running by this weekend I jumped in with both feet.
So I started with one of these
cut off its top and stripped it.
I needed to make a working station for this
It works the same way as my old abrasive saws, but damn is it nice. fast accurate and the cut stays cold.
So I cut a couple disc of steel with the plasma cutter, found center and laid out the mounting for my bearing.
now the bearing will hold the two disc apart 3/4" so I rolled out a ring of 1/2" stainless tube with the ring roller and welded that to one of the disc. (you can just see the edge of it in this shot
With the tutn table finished I turned my attention to the cart. I cut the top off and using 1"x 1" .120 wall steel I built the sub frame
Then welded in the turntable and mocked up the saw location using my old Rigid abrasive saw. (It has the same foot print as the Fein) Now I built the upper deck
to be continued
to be continued
now i have to make a own saw table
