Chopped! The GJ User Modified Tools Thread
...they show a "cut out ".
Not to be pedantic, but the term you are looking for is "cutaway". Cutaway drawings and diagrams have been a staple of design, engineering, architecture, and marketing for a long time.
There is of course no practical use here but it is still " chopped "
Step away from the car with that chainsaw! :)
I found this sad looking MFD era FLEET No. 1270 3/8-inch drive hinge handle at the flea market this morning. Not chopped or modified for a different purpose so much as crudely but effectively repaired. A PO replaced the broken pin with a screw and nut, and peened both ends. As you can imagine, it swings freely with no tension whatsoever. I'm just dropping it in my Fleet Quality Tools carry box with the rest of the ca. 1950 PENENS Master Wrench Set and miscellaneous Fleet/PENENS tools.
Or smack it with a hammer to tighten it up.lol
C'mon, folks this is GJ!
Bore the plug out, press in a sintered bronze bushing, ream that to a perfect fit on your hand-forged, color-case-hardened pin, peen the pin in place forming a perfect, domed head.
There is no other solution.
Or, if you are a You Tube expert, just grab it in one corner of the jaw on your cheap vise, and use it as a press. Should be fine.😆
Leviton
Oregon
Someone needed a 27/32” deep socket and only had a regular Frank Mossberg pressed steel 21/32” socket and a piece of pipe. They made do. I’m most impressed with the service end – not sure how they formed the pipe into a hex opening but it was pretty well done.
Overall length is 5.25 inches.
M.Brane
1 hr N/W of LA LA Land
Looks like they heated the end of the pipe, and then tapped the edges with a hammer over a bolt/nut of the correct size.
mikeinri
That would be my guess. Probably easier said than done to look that good.
Mike
Provincial
Near Salem, OR
I made this wrench from a cheap 17mm import socket. The handle is made up of sections of a failed Harbor Freight plastic clamp. I cut the steel bar into two pieces and welded them into an "L", and then to the socket. I had to heat up the tail and put a curve in it to clear the chip pan of the lathe. This fits a bolt on the motor mount so you can adjust the belt tension of a metal lathe. It certainly wasn't designed to be easy to tighten!
Leviton
Oregon
Someone made a screwdriver out of a screwdriver. They started with a Sears “BF” (Fuller) flathead screwdriver from the mid 60’s (I think that is the era) and brazed an Apex 838 bit holder (Pat. 2522217) onto it. The bit holder is currently sporting an Apex 440 2-PK Phillips bit. The whole assembly comes in at 11 inches long.
Beerhippie
Far NE Oregon
Looks like concentricity wasn't a concern.
whateg01
doo dah, kansas, usa
If that's a square drive bit holder, I struggle to think of a way to get the screwdriver off center. Just shove it in between the corners and it's gonna be centered.
