Chopsaw to tablesaw advice
visedog
India
I want to convert a 14" metal chopsaw into a makeshift wood cutting saw mounted under a table. I am thinking the spring has to be removed and a base has to be constructed. I want to avoid too much welding because of the plastic motor cover.
Has anyone done this previously, and if so what is your advice? Will it be a dangerous thing to do?:scared:
Thanks!:)
HCNDM
Netherlands (tiny little country in western Europe
Thanks!:)
Hey vise dog,
New heard of someone doing it with a chopsaw or mitre saw. I think the lack of a square base makes it more difficult.
Plenty of exaples where its been done with a circular saw:
http://www.instructables.com/id/Convert-a-hand-held-circular-saw-into-a-table-saw/
I have this one saved in my pinterest for a future build:
http://woodgears.ca/homemade_tablesaw/
I think something to keep in mind is the RPM's on a chopsaw. Dedicated wood circular, mitre, and table saws tend to have higher rpms for cleaner cutting than metal chop saws. (1400 rpm vs 2800 iirc)
I guess it all comes down to the model chopsaw you have. And figuring out how to mount it upside down and square to a board / steel plate. Height adjustment is a must to be truly flexible.
That said my apporach would probably be as follows:
1) Remove the chopsaw from the base at the cantilever pivot.
2) Mount the cantilever pivot to an axle on the bottom of the table.
A shaft bearing (x2) and bolt would work for this:
3) Fabricate wooden height adjustment brackets like in the woodgears link above
Keep us posted. Curious to see what you come up with.
V
visedog
India
Thanks HCNDM!
Your wooodgears link is a great idea as it does not involve any welding. My chopsaw has a bolt and a spring at the cantilever point which can be easily removed. I will go ahead with a simple bracket and a bolt under the table for mounting the pivot after I make the square base. Will post the results later.
Regarding the RPM, my chopsaw has a no-load speed of 3800RPM with a 2kW motor. I think this will be sufficient power for ripping wood!
Gotcha640
Houston TX
Just to point out the obvious (hey, it's garagejournal, someone has to):
You won't have a chop saw for a while.
I have old craftsman/sears tablesaw, joiner, and drill press, all with basically the same motor, and I frequently think about making a lathe or a bandsaw or a xyz and using the motor/pulleys/bearings etc from one of the other tools. But I use all those tools pretty frequently, so I couldn't really handle being without, and it makes more sense for me to just buy the other tool.
Table saws can be had for under $100 all day in Houston. Crappy new ones that work, decent used ones that barely work or need repairs.
astroracer
Mid_Michigan
My thoughts exactly. The time and money you will have into "trying" to make this work, could easily buy an inexpensive cast aluminum table saw. I just bought one last summer at a yard sale for 50 bucks. Flipped it for 75. :)
I know Sears has them for around a hundred bucks.
Mark
woody 73
The Great State Up North
Vise dog I am with the other guys on this one, much cheaper to look on your local CL for a cheap saw; had you posted your home town I could have looked at your CL for a table saw for you.
zkling
FWIW OP probably doesn't have a large offering of used table saws where he is located (India).
It would be much better if you could start off with a circular saw.
V
visedog
India
Thanks for the advice! Yes, I am located in India and here I have not seen any cheap table saws (yet). But we have a plentiful supply of 14" wood-cutting blades so I decided to make one myself. Let's see how it works out.:confused:
If it fails, I will still have my chopsaw.:D
crguy
SW Washington
Thanks!:)
I wouldn't even consider doing something like that. You're likely to end up with a cobbled up mess just waiting to hurt you.
Keep the metal saw for metal work, and find a proper wood cutting saw.
