Christmas Angel Issue
pop pop
Virginia
If wrong, mods please move. Our Christmas Angel with moving parts pulled one wire into, so now half the lights are not working. I found the two ends and stripped the covering back - no wire, just white threads. Kept stripping back for about 12 inches as I know sometimes insulation stretches. But there appears not to be a metallic wire here. What am I missing?
Bert_
NW Iowa
Some wire intended for high flexibility have some white fibers woven in with some extremely fine copper strands.
Most headphones use stuff like this.
P
pop pop
Virginia
No, not FO nor LED. Seems to be old school (6 years old?) two prong push in bulbs. Strange to me.
PassnThru
Bowling Green KY
Even the FO would probably still use a halogen bulb for the light source. Can you land the 'wire' close to the light source? Maybe hold the wire close to the bulb and see if light comes out the other end. A flashlight would work also.
pattenp
Virginia - USA
I'm now thinking like Bert. I've tried to repair a broken cord on a leg hair removal torture device my wife uses and the stripped wire looked like a cotton string with some very fine copper threads in it. It was virtually impossible to splice together to make a repair.
dowmace
KCMO
Sounds similar to headphones wire. Take a lighter to the strands there could be Cooper woven into the fibers, the copper wont burn off like the cotton.
Sent from my Pixel XL using Tapatalk
CJ7VFR
Central New Jersey
Can you replace the entire broken wire with some regular thin green Christmas light wire? It might not last as long as the fine wire that is there now, but at least you might be able to make the angle work again.
Jim
