Cinder block foundation replacement?
coppah37
My shop is 30x36 slab with one run of cinder block around the perimeter. The sides of the garage foundation are in rough shape. I'm thinking about replacing one side of cinder block at a time by building a temporary wall tight to the floor and rafter ties to support the wall minus foundation. Then I'd knock all the block out and lay some new block in place. Does anyone have any tips or see anything wrong with doing this myself? Any help or insight is appreciated.
kd3pc
Northern Neck
what is rough shape about the foundation??? Are they crumbling, no longer support the load, etc?? What is the garage construciton?
If not failing, I would parge the block and paint.
This will not be a trivial exercise.
finn
The UP, God's country
Parge and paint.
I did that on a cottage with water damaged block. Tarred the outside below the dirt line, but haven't got around to the painting yet. Use the latex additive with the masonry cement. It toughens the product and makes it easier to work with.
C
coppah37
Construction is standard gabled roof with rafters not trusses. Walls are 24" on center rough cut lumber. Garage was built probably in the 50s-60s I'd say. Exterior is barn board type siding. It sheathing. Walls are insulated everything wired up and mostly dry walled but no mud or anything. I did that in case I ever wanted or needed to get in the wall I could just remove sheets of drywall with a drill in minutes. Sill plate is also rough cut non PT. Sill seems solid in 90% of the garage.
C
coppah37
By rough shape I have some broken blocks in the middle of the run. A lot of joints have mortar coming out. When it rains water seeps under a lot of the blocks in spots.
C
coppah37
Here's some pics of what I'm talking about.
AVIVIII
NH
That's not bad.
Parge coat would do it. Tar or Thoroseal if you're worried about water.
C
coppah37
Yes the previous owners put expanding foam in there. Thanks for the help though folks.
TractorJeff
Elkhorn, WI
4x4's on jacks with a 4x4 on top against the ceiling joists would lift one side at a time.
A guy on here put a couple of good size timbers in his garage. Attached them to the walls and lifted the whole thing on 4 bottle jacks. Cribbed it, jacked it higher. Cribbed it again so as not to depend on the bottle jacks.
I say go ahead and do it!
s14kev
Cinder block (CMU) is not expected to be waterproof. Water is coming in because of inadequate drainage. You will need to slope the perimeter away from the foundation and perhaps run a curtain drain / french drain to direct water away from your foundation. Do you have gutters and if so are they directed away from the foundation or do they dump water next to it? Your current blocks are likely fine. You can repoint the mortar and parge it for cosmetics however even if you rebuilt the block foundation, water would likely still come in unless you fix the drainage.
C
coppah37
I do not have gutters on the garage at the moment. But my fathers house as well as many others have cinder block full basements in their house. No water in basement. My land slopes away on every side except driveway.
C
coppah37
Ended up repointing and parging the roughest part. Also got a pad poured for my propane tanks. Pretty pleased with how it came out.
