Circle 41
dmaxx3500
i just saw this post, looks great, it must have cost a small fortune to run the power from the street,,good luck
RbrtAWhyt
North East Georgia
Re: Final plans...
Howdy,
I took some photos of the final set of plans. Sorry for the 'photos', but I am a computer dummy sometimes so I am not aware of how to take shots from my screen (AutoCad) and convert them to something I can host, then post:headscrat . So, photos you get...:)
I'm sure someone has told you this by now, but if you're using a windows pc and want to take a "screenshot", press CTRL+Print screen. Then open microsoft paint. right click on the big white part and select "paste". You should have a screenshot. Save the image in the format of your choice. JPEG is common and works with most boards...
Robert
Mr. Welsh
News to me...I always plot to pdf and then switch to JPEG. I'll have to try that.
There's no need to press control + print screen; just print screen will suffice but the quality will **** because it's limited to your screen resolution.
Bump for an update.
Mr. Welsh
Ok I tried it...works fine, but I got some weird gray pixels that shouldn't be there.
tmr
I need to see MOAR! :)
You don't realise how much I've dreamt of building my own Garage/Workshop/Guest Room and to live in while (saving!) building later the House!
Truly inspiring stuff to see this unfolding. Major kudos, and respect to Mrs. Passmore for being so understanding :bowdown:
PS. we need more pictures!! :)
theroyz71
Tennessee
Wow, just wow! What a beautiful build. I hope everything is ok as it has been a long while since this thread has been updated.
P
PASSMORE
The Texas Embassy in Sloughhouse, CA
I won't bore you all with photos of rough electric going in. Suffice it to say there are outlets everywhere w/circuits galore to power most anything, well.
Knocking out a few details on the exterior and will get stucco going prior to our wet season.
All in all, going well.
Gath3r
Hopedale Ma
Nice dwelling. Im in the middle of a similair build myself. Almost got the fourth wall up on my 16' X 24' shop... Maybe we can bounce some ideas back and forth sometime.
...im going to go shoot myself now.
P
PASSMORE
4plex, air, and 3ph below
Electrician did not like my opener wiring for some odd reason. He put something called an outlet up there.
Found an anvil along the way
Main panel wiring - panel here next week - 400a of 3ph goodness.
Just a cool little detail. Box set into a beam that will will remain exposed. Now the light for the pool table will be perfectly centered :)
Upstairs deck and stairs up there all sealed up now
Front door upstairs
Looking out the front door from inside
Master bedroom slider door out to side deck
View into the upstairs office
Mr. Welsh
Wow you really did pull the plug on this project...I kind of thought you were just holding out on us.
So are you back in business now or just taking it one step at a time?
P
PASSMORE
Yup, plug pulled for a bit. You do what you have to for the greater good sometimes:thumbup: No worries, we are all good though.
As for fully wrapping it up, good question. We will gauge cash flow and take it from there. I think we will certainly be stucco'd and a darn good chance we will be drywalled. From there, most of it I may do myself anyways...
We shall see :)
Mr. Welsh
Have you been living in the trailer all this time? I can't imagine how much you must want to finish this at least to the point that it's livable.
