Raisedonadeere
I have always used my circular saw where I expect to hit nothing but good wood.
But I have a project where I have to cut some access holes through two layers of subflooring and along the path of contact with the supporting joist. I will remove the visible nails in the top layer and cut just deep enough remove that layer but most likely will hit some nail heads in the layer below. I know I will be sacrificing a good blade as far as it being a good wood working blade after all that but I want a blade that will hang in there for several holes.
What is your approach to this. I admit I haven't done much research yet and will be doing so, but I find so often as I read these threads I run across a way of doing something that most likely I just would not have thought of. Some of them are real duh moments BTW
