kansas cat
- Joined
- Dec 14, 2012
- Messages
- 5
Greetings all, I have just recently put up a new 30 x 50 x 16' pole barn shop building, and have been reading this forum for a while now and learning a lot of valuable info from you guys here. I am putting in floor radiant heat, and just finished installing 1400' of 1/2" pex on top of the insulation and am awaiting pouring of the concrete next...weather and money both being a cause of delay right now...anyway, while waiting for the slab to be poured i am researching and locating the rest of the materials for the heat system. I picked up a Rinnai RL-75il 180,000 btu LP tankless direct vent water heater that had cosmetic freight damage on ebay a while back for part of the heat supply....i intend to build a air to water heat exchanger to take surplus heat from a wood fired forced air furnace that heats my house to at least do some of the hot water creation ahead of the water heater...anyway, i have 5 zones in the slab most under 300' long with one that ended up being about 350'. I also plan to have one zone run upstairs to heat the floor in the future office room and one zone of the manifold run to a water to air heater assy that i have...if i feel its needed once done with the floor heat.
My question right now is i need to know what sizes i need to be looking for for the circulator pump, and the expansion tank. I know pump size needs to be based on the amount of pipe its going to be pushing the water thru, plus the factthat one zone and possibly the water to air unit will be upstairs makes a difference, plus the fact that i will be circulating the water about 15' thru 3/4" pex over to the furnace shed next to the new shop and thru a large radiator mounted near the ceiling and possibly a copper line wound around the furnace hot return air lines. So am estimating by the time i get the upstairs office floor lines ran and the lines to and from the furnace shed and the lines in it there willl be close to 2000' of lines plus the water to air exchanger / radiator and the air to water radiator / exchanger in the shed, plus the tankless water heater. The water will have two areas where it will have to rise to a height of about 8'...1 for the office floor and 1 for the exchanger and lines in the furnace shed.
I know this might sound confusing or complicated, but really its not, just think of it as a normal setup with a main floor and a small upstairs zone, but add a rad and coil of lines 7' above the floor level where i plan to pull some free heat into the water. The furnace shed i built esp to house the wood furnace. Its pretty much fireproof and well insulated with fiberglass. The furnace is capable of heating out home on its lowest setting...air intake shut nearly clear off since i heat with hedge wood only. I only have to add wood twice a day, morning and night. For the past 5 years now i have always noticed the air temp in the furnace shed runs about 150 degrees normally, and if it gets real cold out and i open the intake and feed it a bit more it can go well above that in there...and thats all wasted heat...i sometimes have to turn on a small exhaust fan and dump this heat outside . I figure i might as well use some of it to heat the water for the shop, and i like the challenge of designing and building stuff like this anyway. I figure heat the water as much as i can off this free hot air, then run that into and thru the tankless heater so it can finish the job if any more heat is needed or for when i am out of town etc and the wood is not being feed in.
I should add mention, the 3/4 pex going between the shed and the shop are 3' under ground in 4" pvc conduit and they will have foam pipe insulation around them to reduce any heat losses on the 12' run between the buildings. Both ends come up thru the slab so no outside exposure to them.
Sorry to ramble on here guys, just wanted to try to get ya a picture of what im building and get some of your vast knowledge back to save some trials and errors here.
Love this forum, some pretty wonderful shops on here and a lot of great ideas and tons of knowledge. Thanks so much for any info or help you can offer up.
Steve
Steve
