CL find/advice
x14119
Sanford, NC
Team,
Long time GJ creeper, just signed up!
Anyway, I have been wanting to get into metalwork/welding for a while, and have been looking around for some good thick steel for a fab/welding table.
I found some!
The good:
1. I have two pieces and a frame
2. They are pretty solid— one is 30”x60”x3/4”, the other about 2’x3’x 1”
The bad:
1. RUST
I actually got all of it for $180, and am excited, but need some advice on how to remove the rust before I just take a flap wheel to it. When I de-rust tools I immerse them, but that isn’t really an option here—thoughts?
aafadca
western nc/northern va
You could try pouring on some rust remover such as, Evaporust, Rust Dissolver, etc. Then wrapping/covering it with something like Saran wrap or plastic and letting it sit over night.
Vintage Veloce
San Diego
I have had remarkable good luck with laying paper towels on top and soaking them in evaporust and then covering with plastic wrap (to prevent evaporation).
But with these, I'd build a little wall on the perimeter of the flat surface, and fill the top like a swimming pool with evaporust. Not sure how I would make that perimeter wall...maybe just some plastic tape?
X
x14119
Sanford, NC
Thanks guys!
I’m liking the paper towel/evaporust or naval jelly pool.
I think I will give a quick buzz with the angle grinder and see how that works then go chemical if it is going to be too much work. Thanks!
bad_idea
Pasquotank, NC
If you use the grinder, wear a respirator. That dust will go EVERYWHERE! Makes a mess. Plays hell on your sinuses.
X
x14119
Sanford, NC
I’ll see what the wheel does—recently started using a respirator for just about everything, and it is amazing.
Jason280
Coarse wire wheel will make short work of it, just be sure to wear eye protection!
blair683
Abom79 just finished his steel bench on YouTube. He used a wire wheel on his. He then used this CRS rust converter stuff. Looked pretty good when finished.
bad_idea
Pasquotank, NC
Jack Olsen used an acid on his top. He has info in his garage thread about it. I don't remember what page, you may want to PM him to ask him. IIRC it didn't take long and the results were good.
jonshonda
Wisconsin
Angle grinder with knotted cup brush and knotted wheel. It will make quick work of the rust and paint but won't remove much good material. Wear a mask or respiratory device
sweetk30
finger lakes area upstate ,ny
local guy in my area gets 120.00 to media blast a 4ft x 6ft top . its a brand new sheet that sat out side to long . i tryed 40grit on a flapper wheel and it will work but take bit of time.
when i am ready for mine to be done it will be dropped off at his place and done that way .
OldNeons
Midwest
Another option would be to have it ground/surfaced for a truly flat (and clean) work surface
