Clamp meters and a DC amp indicator.
toolaholic
PA
Hi all, I wanted a clamp meter to test alternator current output on my vehicles. Mistakenly bought this: http://www.amazon.com/dp/B00AQKIEXY/?tag=atomicindus08-20 . It was $77 with tax. My local sears hardware is going out of business. Reason it was a mistake is that I needed D/C. No problem. I only have a old craftsman multi meter. So the fluke will come in handy. Then I ordered this: http://www.amazon.com/dp/B00B3HZWHU/?tag=atomicindus08-20 . Paid $17.95 w/ free shipping on ebay. Anyone use these? Then I figured screw it and went back to sears and bought what I should of bought in the 1st place: http://www.sears.com/craftsman-digital-clamp-on-ammeter/p-03482369000P It was $38.15 on clearanvce at the local sears hardware going out of business sale/sears outlet coming soon inventory reduction. I bought it cause there is no multi meter in my car diaster bag. My thoughts are fluke looks well made but only displays to the tenths not hundredths. Kd current indicator is USA and is analog. The KD will be fun to play with. The craftsman looks ok. Good enough for car tool bag.
T
toolaholic
PA
now i have 3 multimeters. My orignal craftsman and my 2 new clamp meters.
Mark in Indiana
Southern Indiana
I really don't know about the quality of Sears meters these days. I have a 25 year old
C-Man DMM with temperature probe that I use for HVAC-R troubleshooting. Having had bad luck with cheaper meters, I gladly pay the extra money & stick with Fluke & Amprobe. I have 3 different models of Amprobes. One is the ACDC-400 which is great for troubleshooting battery forklifts & automotive charging systems.
bwringer
Indianapolis
It's strangely difficult to find a DC clamp meter for anything close to a reasonable price.
I had the same quest and reached the same conclusion as you -- I bought the Craftsman since it was the only DC clamp meter I could find that wasn't ****-crampingly expensive.
http://www.sears.com/craftsman-digi...00010000100600&aff=Y&PID=6147012&AID=11042411
I use it quite a bit for motorcycle work, and it's worked very well so far and held up fine. As far as I can tell (reading a known load at a known voltage), it's spot-on, but for most DC amperage needs extreme precision isn't a factor anyway.
T
toolaholic
PA
Thats the one I scarfed up for 40% off. I tried it on my yaris and dakota R/t pick up. Seems to work fine!
Don't trust ANY clamp meter down below 1/10 of an amp (100 ma) !
Both of these claim to measure down to 1 ma, but I would not trust them !
ESI 687 80 Amps DC/AC Low Current Probe/DMM - Amazon $111
GTC CM100 1 mA to 100 Amps AC/DC Low Current Clamp Meter - Amazon $144
ACCURATELY measuring current is a bit tricky. Clamp meters are good to "get you in the ball park", which is important. Hooking up a 10A meter to a 50A circuit could be ugly ! If you want accuracy, you will have to "open" the circuit and insert the meter/shunt in between.
cheechi
Triad, NC
I have done a lot of jobs in various shops, automotive, fab, aero, research, worked with contractors, hvac, electricians, and never seen someone use a sears meter professionally. I have seen Innova, Fluke, Radio Shack, and so on. Even plenty of HF and no names.
Based on that I would recommend pretty much any meter over sears.
firebox40dash5
They seem to be mostly Extech rebrands. Maybe not the bestest, but my EX520 and 120A AC/DC clamp work fine. Sometimes Sears does have better prices on theirs, though.
I wouldn't use a clamp for precision either, but that's not what it's for. Good luck running 50+ amps through a meter in the circuit. My clamp has helped me diagnose a few alternators that hadn't fully failed, as well as using it to check various motors.
T
toolaholic
PA
Yeah I want to9 use mine to diagnose alternators! Plus I cant wait to try KD 2423 alternator current meter.
Tawn
Maryland
Thats a great price on a Craftsman 82369 - If I could have found one that cheap a couple of weeks ago, I would have bought it.
Ended up spending more on a Fluke 325.
Ainsley
Ontario, Canada
I bought this one: http://www.amazon.com/gp/aw/d/B0017WRH7O
Over a year ago and it works well for large currents. I was doing a lot of automotive lighting installs and it was key for keeping an eye on current.
Used it a few times to check alternators as well.
You can't expect it to be accurate, but I would trust it to an amp or two.
bonneyman
Desert SW
Agreed. DC volts is easy - getting a meter top measure DC amps is hard.
Even the ole Amprobe "beetle meters" don't measure DC amps. Darn!:sad:
