Clausing 1757 Drill Press
D45
NW INDIANA
Give me the low down on this unit
Clausing 1757
Looks beefy and industrial
Is the chuck normal or does it only accept specialized bits?
seber
Deep East Tx.
Damn fine machine. Sadly I had to leave mine behind when I left Colorado. I miss it constantly. Spindle takes a number 3 morse taper. The beast will handle one inch chuck and bit with ease. Still accurate enough for Albrecht and micro bits. That is assuming it has not been abused.
shawhite
Pretty sure that is going to be a 15in model and use a MT2. Either way you can call Clausing and give them the serial and they will email you a scanned copy of the manual. Not to mention they have most parts in stock.
D
D45
NW INDIANA
Ugh
I thought it was a special spindle......
I don't have any of those bits and was just looking to upgrade from my Craftsman
It's a great looking machine, listed for $500
slowtwitch73
Hellgate
Dude.. get it. You can put whatever you want in there.... not special... good. Drill chuck with a mt3 taper.. off to the races.
That's a fine dp...
D
D45
NW INDIANA
Oh, so even though the spindle takes a number 3 morse taper, it can be changed to a normal chuck that takes straight common bits?
I bet I could get it for 400, and sell my current drill press for 225
snakeeyes
Yeah it just adapts the taper to a normal drill chuck. We use these adapters at work with our larger drill presses. Typically LLAMBRICH or Jacobs ones that are keyless. That Milwaukee one is nice if you have drill bits that are not reduced shank since it lets you go up to 3/4" where most others stop at 1/2"-5/8".
shawhite
Except it’s going to be a MT2. The 3/4HP motor is the giveaway. It’s still a nice drill press it’s in pretty good condition. Made in USA with parts still available from clausing but you will have sticker shock when you get the quote.
PoorUB
Fargo, ND
By it!
A Clausing was on my short list of drill presses. They are a good quality, industrial unit. You will wonder how you go by with the Craftsman once you get it cleaned up and running!
Verify wheather is is a MT2 or MT3 before you buy a chuck. Also Granger is expensive! Plenty other places to buy from, even Amazon.
Maui
Upstate NY
It is a 15” drill press with a 12” x 18” production table and spindle speeds of 260 - 5400 rpm. The spindle is MT2. Buy it!
Davefr
OR
It looks like it's lacking a table lift mechanism. Unless you could buy a table lift assembly, that DP is pretty much useless IMHO. You're not going to be able to make frequent tweaks to table elevation with that huge production table.
shawhite
It looks like it's lacking a table lift mechanism. Unless you could buy a table lift assembly, that DP is pretty much useless IMHO. Your not going to be able to make frequent tweaks to table elevation with that huge production table.
I would hardly say the table lift would make it useless but to each there own. There are several threads here where people have made their own and clausing does sell the lift if you are willing to pay more than what the drill press cost.
timgunn1962
Lancashire, England
Morse taper arbors can either have a tang at the small end, or a female-threaded hole for a drawbar. Unless there is a hole all the way through the spindle for a drawbar (so you can knock the MT arbor out by smiting the drawbar), do not use the drawbar type.
There is usually a slot through the spindle for a tapered drift to act on the tang and allow you to drive the arbor out (or mt drill, or whatever). If you don't have a tang, you have no way to remove the arbor and it's stuck there. Do Not Ask Me How I Know This.
I can't see the slot in the pics, so it's possible the spindle will take a drawbar.
shawhite
I really hope the OP has already went and picked this up because I don’t think it will be available for long.
RoninB4
Under My House
Very common to find one of these models (or larger) in a machine shop. Well made (for what it is...) and plenty good for small shop or home. If no lift one can be fabricated without much trouble by a local machine shop. Wish I had one.
RoninB4
Under My House
The seller told me it does have a table lift
-Required to plug it in and listen to the bearings in ALL speed ranges. Noisy bearings aren't a good thing, should be smooth and fairly quiet (for a drill press). If noisy, estimate whether you want to bargain or pass on it. Visually inspect the pulleys for damage. Also check for run-out on the spindle & chuck. More than +/- .020 then something isn't right. Chucks often get abused/ruined, they can be replaced (and often should) but if it's in the spindle itself then something is bad. Hope it's all good and you bring it home but don't be afraid to pass on machinery that someone else has bunged up and now wants to sell to an unsuspecting buyer. It may be a good name brand but is it a good example of that brand? Good luck.
RoninB4
Under My House
Bearing replacement is no big deal.
Perhaps for some of us but if the OP is unfamiliar with how/what tools go in the spindle perhaps he/she isn't familiar with changing bearings either. There are a few ways to ruin a bearing on install if proper installation procedures are unfamiliar. Not trying to be contrary, just want to advise the OP. I've worked in machine shops for 40+ years and seen many "qualified" machinists that had bad notions of how bearings were to be installed. A buddy that works for NSK as a field tech says he sees it a lot too.
