Clausing 1860 Drill Press Motor Size
Tennessee Cattleman
East Tennessee
Been thinking about replacing a 3/4hp old Westinghouse motor on a Clausing 1860 drill press. Trying to decide on 3/4 or 1 hp 115v motor, drilling steel, never change it out of low speed. How would well would a Baldor L1307M or L1310M work on this old press?
Trey T
Houston, TX
seems like a good fit. Assuming the frame and shaft fits, the critical criteria is the RPM, which appears you got the right one. For 120/240 1ph motor, you just have the 1800rpm or 3600rpm. The 1800rpm will yield higher torque than the 3600rpm @ #HP.
shawhite
Personally I would go with the 1140 rpm (el11308) if you drill mostly metal. But honestly for the same price you could find a new 3 phase motor and vfd. This is the route I went. I found a new in box baldor 3/4hp 3ph on eBay for $60 then another $150 for a vfd and now I have infinitely variable speed on my drill press
T
Tennessee Cattleman
East Tennessee
Looks like someone was afraid to mess with the allen screws to adjust the belt, so they just bent the motor cradle to adjust it. Plan on putting a switch and cord on it anyway since the cord on it is badly cracked. Kicking around the ideal of just going ahead and putting a new motor on while into it, the old motor is a little noisy and the shaft has got some up and down play. I will be on keeping it 115v and single phase, a motor around 1140 rpm would be nice but pricey. The old drill press seems to be in very good shape except for the table, it's been drilled a lot into the table.
tarbellb
Oregon
I have been upgrading my nice but older Delta DP lately. While I agree a 3phVFD would be a great upgrade, a simple upgraded motor swap might make the most sense.
Finding a decent used 1hp/1850 or 1140rpm motor shouldnt be to hard.
Perhaps you will find my upgrades interesting as well. High quality keyless chuck, foot operated switch-
Keyless chuck post-
http://www.garagejournal.com/forum/showthread.php?t=359134
Foot operated switch link/post
I ended up going with a new foot operated momentary switch. Gotta say, pretty nice quality for the low price - http://www.ebay.com/itm/400421860259?_trksid=p2057872.m2749.l2649&ssPageName=STRK:MEBIDX:IT
Love having two hands available for start up.
This thing purrs...
