OccupantRJ
Does anyone here have a 5900 series metal lathe with the clutch option who is running a vfd? I am curious how the vfd handles the assumed amperage spike when the clutch is engaged to spin the chuck while the motor is already running.
My unit has worked fine in testing using a static phase converter, but I am now permanently installing the lathe and seeking input relative to how a vfd may react with the clutch usage.
It may be a case of the vfd needing to be upsized, but I have no info relative to this to go on. The motor is 6.5 FLA, 2 hp, and the Teco L510 2 hp vfd is rated at 7 amps.
If you have this lathe type WITH the clutch running on a vfd, I would appreciate your experiences and input.
