Got a 30' aluminum flag pole at my workplace that needs prettying up. I guess it's "anodized" aluminum, or perhaps "spun" or "brushed" aluminum, and looks to have the very fine brushed or spun looking texture going around its diameter. Anyway, over time and neglect it seems to have a dirty algae type mildew or whatever growth/residue especially down at the lower third that I'd like to get off before trying to shine or buff or whatever it would take to get it looking as shiny and clean as it can get. The whole thing from top to bottom generally looks dull and some blackish tarnish or whatever spots going around up toward the top where the metal clips on the flag rope probably rub around and bang on the pole up there. So I was thinking if at least trying hitting the lower algae-dirty part with a 3200 psi pressure washer to see if I can get that stuff off, and if that doesn't do it figure out how else to scrub it off. Then once I finally get the dirt and algae stuff off, maybe use steel wool I guess and go 'round and 'round with that all the way from top to bottom. My extension ladder has the pole V-type attachment so I can lean use that to climb up there halfway safe-like anyway. Any suggestions/comments on techniques how to do this most effectively/efficiently/properly would be appreciated. Don't have a cherry picker available, or any fancy specialized equipment. Probably gonna involve a lotta elbow grease but the less the better.
Here's a couple pictures, for what they're worth:
for the chemical method aluminum brightener sold for pontoon/boat and truck applications. As well as the scotch bright if it is heavily corroded in a section. I forget what the designed application is, but they made telescoping poles that have a ~4x6" square mounted on the end with a gimbal. Could probably use that to reach the higher sections you can't get by hand.
I hope.
Need a little more detail, please.
