LSVLance
Hello all...I've been a member here for a long time but haven't been active in many years. Here is my Garage Build thread from my Kansas City house that we just recently sold. Unfortunately most of the pics were lost in the Photobucket debacle...
https://www.garagejournal.com/forum/showthread.php?t=83249
We recently decided to sell everything and relocate to Phoenix, AZ (Peoria area to be precise). My wife has wanted to move there forever and I told her that if she could find a house with the kitchen and floor plan that she liked and the garage space that I needed...and that we could afford...I'm in. Much to my surprise...we found just that.
Apparently they build subdivisions out there designed to hold large "RV Garages" next to the houses...lots of these subdivisions... After a few months of searching, we found the perfect spot for us. We are building a 3100 sq ft house along with a 1634 sq ft RV garage on a 8/10s of an acre in a gated subdivision in town. I'll have everything and more that I have now on our 11 acres...without a stitch of grass to maintain!! I'm stoked.
Because of the double move, and that most of my shop equipment was second hand or hand me downs...we decided to sell just about everything in my shop and buy all new once into the new place. My tall 48" tool chest, all my hand tools, and a pressure washer are all about that I am bringing from the old shop to the new...hence the name "Clean Slate".
Here is the plot showing how the house and RV Garage will lay on the lot.
Since this is being built by a production builder, I am limited in such that I can not make any custom changes to the plan. When having them build your home, you basically pick your options out of a catalog and that's how it is. If I was doing a custom build, there are a few things that I'd do differently but in an overall sense, I'm happy to be able to use this as a starting place. We feel lucky to have found a lot and builder that accommodates all of our "specific needs" we stated before starting the search, it wasn't easy trust me.
One of the challenges has been that they use tension cable slabs for the foundations. This means basically no drilling of the floor in the shop to install a two post lift. I would prefer a two post like I had in my old shop, but will make do with a really nice commercial grade 4 post with 2 rolling jacks. Here is a pic of the RV slab pre-pour showing the tension cables in place inside plastic sheaths.
They will tighten those cables down to 30,000 psi of tension once the concrete begins to setup. I have learned you do not want to hit one of those with a drill bit after the fact.
So here is the floor plan of Clean Slate
On the front left will be a 14' tall door, front right will be a 9' tall door...there will also be a 14' door on the back opening up to a 50x50 flat graveled area behind the shop inside the 6' tall concrete block fence around the backyard.
My plan is to build a small office for me to work out of between the bath and 9' door, the put the 4 post lift between the office and the door. The other side of the garage will need to house our RV.
That's about as far as I've gotten with interior plans. I need to make a list of all of the equipment I plan to install and spend some time with the builders "space planner" to see where it'll all fit.
I got these pics just yesterday showing the slabs being poured...so stuff is getting real. Closing date is estimated to be Feb-Mar 2018...so I have some time to plan.
House on right, garage on left.
House
Garage
Here is what the front elevation will look like once complete, only real difference it I'll have a second 9' door on the right front of the garage where this one has windows with a living area inside that area.
Anyway, here's my reintroduction to Garage Journal with our new build project 'Clean Slate". I know I'll be perusing all the new and old builds here and making lists of things to incorporate into my new shop. Is it March yet???
House
Garage
