Cleaning a Tire Plug Tool
NoSkills
A small town west of Knoxville, in beautiful East
I've carried tire plug kits in my RZR for years, but never needed them on the on the trail. However, I've had to plug two tires recently on my DD vehicles for punctures that were in the last tread block, too close to the outer sidewall for the local tire shops to fix. So, I now have real, hands-on experience plugging tires, and a gunked up plugging tool. This is the tool you insert the gooey thread thing through to insert into the tire. How do you clean it? Or do you just keep using it until it's unusable and then just replace it?
TobeyA
TX
I just keep using it. I lose them before they are too gunked up to use.
charbar
Midwest
Ive never cleaned mine either. I suppose soaking it in a little gas and then wiping it off might work though....
AA/FC
Never cleaned a plug tool... And I've been using them for over 30 years. In fact, the only clean plug tool I ever saw was when I bought a brand new Safety Seal plug kit for a service truck that I was setting up about 8 years ago.
wafrederick
Holton,Mi
Never had to clean one,nothing on it due to using the rubber plugs which are better than the junk rawhide plugs that do not seal worth a ****
N
NoSkills
Thanks for the suggestions, everyone. I thought this was going to be a horrible PIA because of how sticky the cords are, plus adding rubber cement, too. The recommendations made me realize it probably wouldn't be too bad after all. A couple of minutes with a Gunk Multipurpose wipe cleaned it up nicely! Really appreciate the knowledge available from the GJ collective.
Old Man Roger
Palm Coast Florida
I’ve never used glue with a tire plug, I just make sure I create enough friction with the reamer to heat the hole. The heat makes the plug slide in easy and it melts the glue in the plug enough to seal the hole.
