cleaning coil stock used for soffit trim? Polish?
Innovate1
Have aluminum flashing that was bent from coil stock that is about 20 years old. Needs a good cleaning and have noticed some areas where the coating is deteriorating - perhaps some light corrosion. The soffit panels are plastic and also need cleaning. I have seen suggestions of power washing but seems like that would push water above the panels (they are vented) and drip dirty water from dust above panels. Would have to let things dry out and still clean them again. Any suggestions? And wondering about waxing the aluminum. Probably should have done it a long time ago... For those that say just replace it, the installers bent a bead that sticks out - I think to help it lay flat and also give it some detail and I would like to keep that. It's not so bad I need to replace it - just a bit dirty.
Yankeefarmer
Connecticut
Have you tried cleaning it? Wife and I have been very satisfied with the results of just using Simple Green and rinsing with a garden hose.
racecougar
Missouri
A house wash, a brush on a pole, and a garden hose does a good job of cleaning all of that without being as aggressive as a pressure washer.
Renegade1LI
long island ny
Try zep TNT works great on plastic and aluminum, removes the black streaks on rvs.
P0234
NoVA
Get some Mr. Clean All Purpose (floor) cleaner, mix at 2x concentration on the bottle. Its basically a rinseless wash. A light bristle brush and get to work. Just keep re-dipping the brush until it gets clean. Dry with a towel if you want.
Mr. Clean is awesome stuff.
