Cleaning cordless tools and comfort grips
2ndGearRubber
Pittsburgh
My job involves many gross things, and I'm trying to make my electric tools a bit cleaner. Over time, my M12 tools especially, get caked in gunk/grime/filth which then transfers back to my hands when using the tools. Annoying. Today I got a new M12 hex impact, to replace my well worn non-fuel model, and I'd like to try to take better care of it.
My main issue is the black soft rubber area. Obviously that stuff hates both oil and brake clean, so I do what I can to limit exposure. A light wipe with a rag works, but it's never actually clean. Frankly this is one of my big gripes with comfort grip anything, so aside from my impacting air ratchet all my tools are metal/composite body.
So what are you using to clean these tools of brake fluid/grease/coolant/dirt/oil/tape residue, etc? My long neck M12 ratchet looks like it's been to hell and back compared to my new hex driver. My M12 tools end up looking matte red due to the dirt and junk all over them.
2ndGearRubber
Pittsburgh
Penetrating oils and wd40.work good on plastic, but I'm worried about hurting the rubber grippy stuff or making it swell and separate from the tool.
Tub of towels seems to have mixed reviews, I'll look into simple green. Just spray on a rag and wipe?
JradM
Alberta
Yep, that's all I do. With comfort grip pliers I just spray the tool. Power tools I tend to spray the towel.
Fedwrench
Valley of the sun
I think 409 or GP Cleaner works too.
  • Like
Reactions: GTO
itwnexus
Will simple green work to get all the caked on grease and dirt? What about "Grease Lightning" or "Purple Power"?
Zewnten
Simple green and a tooth or nail brush or the tub o towels works well for me. Kind ocd about cleaning everything Friday so Monday I can make a mess again
Not a pro, but Simple Green is my garage grease cutter. I keep 4x diluted for most cleaning, and an undiluted bottle for the really gross stuff. On the caked on stuff I try to scrape the worst off, leaving only a thin amount for the SG.
DHCrocks
Hawaii
I use wipes like grime boss. it also takes off latex paints which seem to get everywhere when I'm painting.
mfewtrail
Greased lightning wipes work well for me on tool grips. I clean up the tools pretty much immediately after completing dirtier jobs, so that probably helps to some degree as well.
Fly YX
Be careful about using WD 40 on plastics. I had to do a job that I had to replace all the electrical connectors because they told me that they got WD-40 on them and the degraded the plastic overtime.
vwpieces
Hills, PA
I use WD40 from a gallon can, in a had pump bottle. Squirt some on a terry towel or microfiber and wipe the tools. I have 15yr old Milwaukee NiCd with black grippy handles and no issues.
JradM
Alberta
Full strength simple green is a very good degreaser. It will remove caked on grease, but you make need to let it sit for a little bit if it's bad. You can just spray a rag and wrap it around the tool handle.
I would not use purple power or any other degreaser the same way. They might be more powerful but in my experience they're too caustic and might damage your tool.
Simple green is strangely perfect for tasks like this. It seems gentle on surfaces in comparison to most degreasers - but still cuts grease and oil like nobody's business.
Jeepster04
If they used a rubber that is harmed by anything typically used in a shop (like WD40), I would buy a different tool.
SS5150
NE IL
I use Goo Gone to clean my soft grip tools (M12, soft grip ratchets, and bi-material screwdrivers). It's a 2 step process though, Goo gone a rag, wipe the tool clean, and then a clean rag to wipe off the goo gone. The nice thing about the GG is it won't take off any printed part or ID numbers from the tool.
dnschmidt
Phoenix, AZ
I prefer Super Clean but Simple Green and any of the waterbased degreasers like Purple Power all seem to work equally well. Just make sure to wipe down with a lightly water soaked towel after using to make sure you got rid of any of these.
Billy Jack
Pittsburgh Suburbs
I'm not a pro, just a weekender, so my tools get cleaned after every job. I keep a spray bottle of mineral spirits paint thinner on the bench.
All the tools both hand and power tools get wiped down with a dampened cloth after every job.
I've been doing it for years and have never seen any deterioration of plastics or rubber grips.
Bill
39 LaSalle
TN
I too am a weekender, but I have never had any issues using Tub O' Towels on my Milwaukee M12 and M18 gear and I swear by them. I give my tools a good going over after each project.
BOOT
Some kind of degreasing hand cleaning wipes would prob work, see some used in a video but don't know the brand...
Indexmill
Central NC
Be careful with cleaning solutions on plastic. Chemical incompatibility is a real and big deal with plastics. Some plastics will stand up to solvents and many will not. Ask me how I know not to pour gasoline into a Styrofoam cup (on my parents asphalt driveway many moons ago). Even 409 can destroy some plastics especially if the plastic is under load. Dawn dish detergent and warm water might be best if uncertain.
2ndGearRubber
Pittsburgh
I decided to try out grime-boss cleaning wipes. It has a resealable lid on a flexible plastic container. Some reviews said the tub-o-towels got so beat in shipping the popped open and dried out.
Buckgnarly
VT
SK wipes, but guessing they are NLA so here's the maker....they are AMAZING for cleaning M12 tools. I clean them before any interior job that matters....
2ndGearRubber
Pittsburgh
I know that pain, just swapped an evaporator in a tan colored interior bmw this week, right after a wheel bearing/ball joint/exploded axle on an old taurus. Very annoying to be using dirty tools or be dirty yourself. I had axle grease soaked to my soul but I still made decent time pulling it.
I ended up only beating flat-rate by about 3 hours due to wasting 30min wiping down the interior afterwards. Never done one before, so I was okay with that time, but I KNOW I lost an hour due to hand washing and cleaning. Thus, this thread.
wkndwarrior29
NorthEast
Put a little goop on a towel and wipe them down, it will make your hands soft and won't damage the plastics.
Badgerstate
Columbus, OH
I work in automotive manufacturing and we use a lot of Milwaukee M12 impacts. For the past 1.5 years, we've been wiping out guns down every 2 hours with alcohol and theyre the cleanest theyve been in years. Might try that.
rk_tek
Bella Vista, AR
I use full strength Simple Green or lighter fluid. If those don't work, I use alcohol. I also wipe down extension cords and air hoses with Simple Green and it does an amazing job of cleaning grime before taking them indoors for other projects.
M635_Guy
NC
I've been using a bit of brake clean on a shop towel. I did notice it took the serial # off the sticker - oops!
I bought a six-pack of the SK wipes when they put them on clearance. They work really well. Once I use those up, I'm guessing I'll go to Simple Green.
