Cleaning fiberglass batt insulation
crazybrit
Portland, OR
Attic above my garage. So insulation is paper side down.
There was only about 60% of the surface covered by plywood and I guess sometime in the past they must have replaced the roof.
As a result the insulation (R19) is pretty dirty.
Shaking will remove some of the larger pieces of **** but not much else. A vaccum or a brush quickly starts removing insulation.
Pondering blowing it with compressed air but I figured I'd ask in case there is another effective way of cleaning I'm not thinking of?
Mike70
I don't understand why it needs to be cleaned. It is in the attic, should only be visible when you are up there. I don't think the dirt will affect the R value any. I would leave it alone and do a more fun project.
sixty4
CT
I had a roof redone at a rental house I own. That one looks the same way, I may just add to whats there. If you find a good way I would be curious myself.
dogdog
Don't shake it, those will itches, don't wash it with water, it will grow mold as well. don't clean it with acetone, making it a lot more flameable... and yes fiberglass bats are flammable...
I would just replace it, if it is moldy, if it is just dusty, I have just vacuum with a shop vac with that attachment.... ... yes hand and neck will itch for a bit.
this attachment... add a course mesh to it if
some scrap mesh like these.. to prevent the glass strands from spearating and vacuumed into the shopvac
jack stand
Lakes Region Maine
I don't understand either, why someone would "clean" f/g insulation. BUT if it's some kind of health or allergy situation. Replace it with (2" minimum) rigid foam, cut to fit inside the framing.
F/G insulation is a big air filter that will look the same in a few years. The attic/roof placement is particularly prone (and designed) for air movement up and out, usually at the ridge or gable vents. Air moving through f/g also dramatically reduces its "r-value".
mike93lx
Richmond, VA
No you cannot clean it. Any suction or compressed air will rip it apart and any water will promote mold growth.
Some dirt/dust in it isn't harming anything.
Replace it if it bothers you
C
crazybrit
Portland, OR
I guess I'll keep my method on how to clean it to myself then.
Yes, I guess I will have to cope with the knowledge I'll go to my grave without knowing.
@dogdog thank you very much for taking the time to answer my question.
Your suggestion worked well.
I only had some finer mesh but it worked out. I found with the finer mesh I could use the brush attachment to agitate a lot of the dirt off without removing (based on inspection of the inside of the shop vac) any insulation.
Thank you again!
