I'm curious, what methods do you guys use to clean files and rasps? I have been sharpening lawnmower blades and I usually have pretty good results with a simple ******* file and then polish the edge a bit more with a medium grit dremel sanding drum. I have used a bench grinder in the past to sharpen blades but it's a bit more challenging to do that with mulching blades, so I stick with the better control and finesse I have with a file.
What I noticed though is while using the file it got caked up with metal shavings. It would cut good for awhile then I would have to rake the shavings out of the file with a nylon brush. Is there a better way to keep the file teeth clean?
