Cleaning garage floor with snow
glmron
Middlefield Ohio
This time of year I get a lot of junk, salt, cinders, mud on the garage floor. I found a good way to clean it up, I take a couple shovels of snow and dump it on the floor then push it around with a broom for a while, after it gets brown and dirty just scoop it up and and dump it outside. Works with oil, antifreeze, brake fluid, ****** fluid, not very environmentally friendly I must admit but it works great.
jlckmj
SE Wiscosin
Funny you should post that, I just did mine yesterday. Another thing that I found that helps even more than plain snow, is saw dust. After I pushed the snow around and loosened up the dirt and grime, I spread saw dust and that absorbed the dirty water. I then scooped it all up and put it in a garbage can. My 24 x 36 garage floor only needed about a 5 gallon pail full of the saw dust.
Of course, it works best if you have heated floors!
Jim
shocksandstrutz
Wentzville, MO
yup....just scoop up that oil,antifreeze,brake fluid,etc....and just dump it outside......
no different than the thousands of cars that leave it behind on roads, parking lots and driveways and it raingin or snowing and doing the same thing.....this is just on a smaller scale....
also, i just did this too, since it just snowed here in the STL and my garage floor was a mess from building a bookcase and doing the rear suspension and brakes on my MIL's outback
Dan_inthewind
Temiskaming Shores, Ontario Canada
I do not have much chemicals hit the floor but like you I have been using snow since I moved in.
Open the door and just broadcast it right off the snow scoop. Let it melt and squegee the floor.
LEVE
On the Willapa
Mix some wood ash with that snow and you've got a winner. The wood ash is a great cleanser...
Dan_inthewind
Actually because of the sand in it, mine goes into a bucket and when that is full it goes over the the dealership I worked at and into the tank.
I do all I can for the enviro and keeping it clean but sometimes I wonder why when you look at some of the wrecks on the road. Fuel leaks, antifreeze leaks and every other type of leak.
But I do feel better because "I would never just dump it outside".
