I'm a major fan of mini-splits and really would not be without them. BUT, cleaning these things is difficult at best. Everyone here is pretty mechanical but a few things to consider when putting them in. When you buy, make sure you have a highly detailed step by step disassembly procedure. If someone says it is on-line have them show you. I was the Fujitsu rep for 12 years back east and I have 7-9 or 12 RMLQ evaporators between my daughters, friends and my homes. The "Disassembly Instruction" which I can access in the "contractor section of the website"are incomplete and of limited use as a result.
Be careful of the drain line on reassembly, if you break the unit down far enough to drop the drain pan and fan. I do not drop the pan, but do remove the air sweep louvers to be able to spray the fan blades for cleaning. A dirty fan can cost you 40-50% of your air circulation.
Manufacturers make much of the point that you can install the evaporators within 2" of the ceiling, but cleaning the back coil surface is a freakin' nightmare when you cannot get at it and about 40% of your surface area is back there.
It is imperative that these things be cleaned regularly and most people are not doing it.
I did not install a mshp in my shop, but am thinking of doing so. If I do I am going to put up a sheet metal cover on the wall. I will then fabricate a sheet metal cover to go over the evaporator for times when I am really making a mess in the shop. I have central and ambient air dust collection, but when I see how crapped up these things can become, there will be times I want to cover it up.
Cleaning the condensing units (all are roof or wall mounted) is a piece of cake compared to the evaporators. Just keep the electronics dry.
I have been using the NuCalgon evaporator fluid in a pump sprayer.
I am going to look into making an electric pump sprayer to simplify and speed up the cleaning process. In fact, does anyone have any ideas on a pump that would work. It has to be a low pressure system as it takes almost nothing to bend the fins. Where are "fan" nozzles in brass available in 1/4"? Remembering those 2" from the ceiling coils, a couple different wands would be necessary, but I can bend those up. There is a battery operated sprayer for cleaning coils but I'm going to see what I can make up before pulling the trigger on that.
I'm off to clean the bedroom evaporator. Oh, the joy!
As a business opportunity, I think there is as much or more money to be made cleaning mini-splits as installing them. MSHP's have been the fastest growing segment of the HVAC industry over the last decade and I do not think people are getting them cleaned. Learning the procedure for each manuf would be a chore, but once done I think a guy could go around to all the hvac contractors in the area and say you are in the cleaning, not installing business, and maybe pick up a lot of leads. Many contractors do not want the service business.
