Above 1200 Sq/FT Cleaning Up My Shop
Rex_A_Lott
Upstate South Carolina
I'm curious to see how well you like the shear/roller/brake combination, and how well it works for you. I'd seen those but was afraid it would take up more space than it was worth to me.
Just an FYI, there are several threads over on the allmetalshaping site about the throatless shear needing a little tuning up to really work well. They are a knockoff of a Beverly shear, so that may help you in your searching, should you choose to look .
When I worked at Michelin, they had a pretty nice fab shop, with powered shears, rollers and brakes. Since you have a lathe, it would be fairly easy for you to machine a round bottom groove near the ends of your slip rollers for rolling rings from tubing or round stock. Another thing they had done was cut a slot the length of one of the rollers so that you could always be sure of getting the metal in the machine square. Just something to think about when you run out of something to do.:bounce:
Good Luck
O
oldironfarmer
Terlton, Oklahoma
Good Luck
I generally don't like combination machines. But I really want a shear and brake. I looked around for something which would handle 16 gauge, or at least 18 gauge but the price jumps dramatically. This one was $320 so if I wind up using it and still want something heavier I can go to a multi-thousand dollar machine and hardly miss this cost. I'm confident it will brake shorter lengths of 18 gauge but probably don't want to try shearing 18 gauge. It will be fine for aluminum. So we'll see.
The slip rolls do have grooves for bending wire and tubing. But I'm looking for things to stave off boredom:bounce:
O
oldironfarmer
Terlton, Oklahoma
More on the shear/brake base. Drilled the holes for mounting.
Then set the frame up on the hoist legs, bolted the two mounting beams to the shear, and lowered the shear/beams down on the frame for tack welding.
After careful tacking to avoid warping, set the shear off and welded out the frame. Added 5/8" nuts on the back of the base for screw adjustment, and two more nuts on the front for feet. Only the two rear feet will be adjustable.
Then I gave it a coat of orange paint. I'm partial to orange, maybe I have some Allis blood mixed in with the IH blood. Or my Oklahoma State roots are showing. I'm not certain, but it is a nice utility color.
Decided to take Bob up to Missouri Monday, so he is loaded on the trailer ready to roll. He will come in handy setting 12 ft steel poles, and I have a generator and propane tank to retrieve from my father's house.
It may be Tuesday (second Saturday of next week) before we actually try to shear some steel.
Thanks for stopping in :thumbup:
O
oldironfarmer
Terlton, Oklahoma
Andy, your stand is looking great..:thumbup:
I like your choice of colour as it just finishes it off:thumbup:
Regards
Thanks, Steve!
I mounted the shear onto the stand, then adjusted it. That took a while. Then of course I had to cut something.
Roof flashing again. Thought I'd try to make a dust pan. A few cuts and bend past 90 for edges.
Came out ok, but warped because of the ribs I put in it.
So I worked and worked on it before I figured out it was the ribs, after I took them out it is straight enough.
So far so good. I'm going to like this.
Thanks for visiting!
jimreed2160
Tallahassee FL
I can see it now--bright lights and those twirly things that used to be on car lots.
Andy's Brooms 'n Pans
(socks knitted while u wait)
Muffins and Pies out back
-Y'all come back now, y'hear!
:beer:
dchance
OKC
Andy the work looks great. But now you have a problem to solve. How to put the beads in and keep it flat. You can think on that problem as you pour muffins.
Are you going to put a 3 foot handle on the dust pan?
Dwight
O
oldironfarmer
Terlton, Oklahoma
Dwight
Thanks for the kind words.
Probably no 3 ft handle. Primarily for bench use.
I think I can roll flat, just have to pay attention to the angle it enters the bead roller. I've had mixed results.:eyecrazy:
But, at least I've got something to learn now, and something to do to stave off boredom!!
BUGTHUG
Kansas
I can see a new product in your future. Of course a person who makes brooms, must make dust pans, its only natural. Its that or offer free rides on the brooms!
Rex_A_Lott
Since you have the English wheel, you can pre- stretch the area where you are going to put the beads and it will be flat when you are finished. Another new toy to play with.;) Good luck
shortykorte
Tallahassee, Fl
Nice stand. I have some bent I-beam that could be cut down and used like that.
Like most HF stuff where the brown gunk has to be removed and the tool adjusted, did you have to do either for it to shear properly?
CudaChick1968
Member Emeritus
Northwest Tennessee (38230)
If the broom fits, ride it. :rocker: Depending on the mood, I might be inclined for a test flight.
Keep up the fine work!!! I dig this thread -- so many fun personalities here.
drivesitfar
Andy: i'm not a fan of HARBOR FRIEGHT brand or imported tools, but your homemade stand has my attention. nice paint job and nice touch rounding off the corners so you or your helpers or grandkids won't leave part of their foot on the corners that could have been there.
i wish you the best on selling your parent's farm and with your marketing skills, personality and your gift of gab i'm sure you'll find a buyer soon.
are you setting up all this cool metal cutting, bending and forming tools to get ready for DodgeStudie? or maybe cause you might want to spiff up maybe 50 tractors and a CABOOSE?
Jim: i bet if Andy's wife was healthier and hopefully she will be a spot on the map marking Andy's farm as sort of the MIDWEST DISNEYLAND might be a possibility.
O
oldironfarmer
Terlton, Oklahoma
Cute, but broom makers are prohibited from making transportation jokes. The dust pan was just to make something rather than just bending up stock for drill.
I have so much to learn. I see the beads should shrink so stretching first should counter that action. I have not unboxed the English wheel yet, and need to go back to HF to buy their extra wheels. It only comes with a sharp radius wheel.
As in bent, rolled? Or just bent? Rolled would be very cool if it's rolled the easy way. Bent you just cut out the bends. Issue with bent is the flanges distort so it won't be flat in the bent area.
It was all out of adjustment, so I learned a lot about it as I was figuring out how to adjust it. The instructions were minimal. But it is 2017 and instructions are a thing of the past. It was not too dirty, however, just covered with grease and oil. And a shear needs to be kept lubricated.
The manual recommended an 8% gap between the shear blades and that would be 0.003" for 20 gauge. There is an adjustment to bow the moveable blade but I could never get a consistent 0.003" measurement across the full width. I settled for 0.003" on each end and less in the middle. When you load it, it will distort anyway. It is hard to cut 28 gauge on a 20 gauge setting so I'm pretty happy with the results so far.
Free broom for a picture!:rocker::rocker:
PM your address and it will be on the way:thumbup:
There are a lot of misfits stopping in here, aren't there! I have no idea why:dunno:
Thanks for your comment on the stand. While it is pretty utilitarian it is heavy does not move when you operate the shear.
Sheet metal tools are an attempt at making patch panels for may old rusty cars and trucks I have. I hope I learn to make some acceptable panels.
I am a reluctant seller of my folks farm. Our family homesteaded it in 1823, pushing 200 years. It is still a homestead in the original family and there are not many of those left. Even in Oklahoma where they were homesteaded as late as 1905 or 06. A lot of history there, including an incident during the Civil War when the Union Army cornered some Bushwhackers on the family farm. The family took refuge in the large log cabin and reportedly were firing south at the Bushwhackers and north at the Union soldiers, trying to get them all off the farm. Surprisingly there were some rather stubborn folks in my heritage. Glad that's not an inheritable trait.:lol:
My brother and brother-in-law and I put up the sign my brother had had made. Here they are strapping the poles together so Bob and I could set them in the holes. Brother and I had welded pins on the uprights to go into the ends of the crossarms so we could just slip them together in the field. Then we rely on the tension of the sign to hold everything tight. We packed dry concrete mix in the holes, 30" deep into still black gumbo.
And here's the finished sign, Bob, brother, and brother-in-law, all in a row. Busy highway, sign will get lot's of exposure.
I'm beat, left the house about 6:00 this morning, drove 4-1/2 hours, worked pretty hard hand digging holes, setting the sign, and cleaning on the house (not done) and driving 4-1/2 hours back home. I also loaded up my dad's whole house generator to use at my house. Air conditioning is getting to be more critical at my house.
Thanks for the comments, guys.
And thanks for all the visits!!
1/2 Cup
Member Emeritus
Shepparton. Victoria. Australia
Andy, I can understand how your new acquisition will almost become the go to piece of equipment very easily, the more you use it the better it gets..:thumbup:
Now that would be tough to go through - selling the familly home and all the fond memories that go with it. All the best..
dlcwent
Member Emeritus
coastal maine
Does this mean that you'll be giving a free dust pan with every broom someone buys? That is going to cut into your foundry time seriously.:D
And thought I had gone away. (Your not that lucky):lol_hitti
jbmatth
Northern Ok.
Andy,
Cool new tool acquisitions, but since I was late to the tool party could you share photos of the bead roller? I feel like you've told me where your parents farm was but I can't remember now, too much other junk stuffed into the gray matter at the moment.
JB
O
oldironfarmer
Terlton, Oklahoma
I need to make a coin box for the Coke machine. I have never used a shear nor a brake before, so I have to get better. But,, I have to practice to get there:eyecrazy:
Thanks for the condolences on the farm. The good news is that my brother, sister, and I are getting along completely with our folks having passed on.
Just curious where the farm is located. My family lives in Springfield, MO.
Collins is at the intersection of MO 13 and US 54. Farm is 1-1/4 mi south on the east side, we put the sign up on hwy 13.
Andy what gage metal did you use for the dust pan?
31 gauge galvanized flashing. I have a roll of it so will use it for anything it is suitable for.
Reusing blank sections of used punch cards.:lol_hitti
Free dust pan with every broom! At the rate I'm selling brooms, yes:thumbup: I can give one away with every broom and not have to make any more!!
Foundry time has died. I've needed to do a few things and foundry is all optional.
I was wondering about you so I sent a search party out. They did not return.
Maybe it's me. So I was glad to hear from you :)
Still looking for your visit!!
Andy,
JB
PB ate my bead roller pictures:sad:
Got my new old generator unloaded. 21 kw, that's 87.5 amps at 240 v. That may power everything in the house.
Finally got back on hammers. I made a hammer for a friend I expect to see tomorrow. As my friend Vladimir would say, came out so
Thanks for the comments and visits!!
shortykorte
Tallahassee, Fl
Wow 1823! That's remarkable. The Korte farm in Nebraska celebrated 100 yrs a few years ago. Sadly my cousin just lost is wife, she was a big part of the operation. When he stops, he will be the last Korte to farm.
OutlawDrifter
KS
Andy, having just went through a similar situation with our family farm. I totally understand the reluctance. Mine didn't have quite the history yours does, but one thing it did have was MY whole history. I grew up on that land and it was a bigger part of me than I realized. When it came time to auction off the personal items in the house and shop I was the one everyone looked to for what it was and background. The house, out buildings, and land had sold a few weeks earlier. Keep the memories close to your heart, that's the best advice I can give.
By the way, love the completed hammer, it looks great! I'll be following along on the multipurpose sheet metal setup.
O
oldironfarmer
Terlton, Oklahoma
We have come to the realization that nothing is forever. I've never really appreciated the age of the farm, it was 180 acres when I was growing up (kept me confused until I finally bought a 160 acre farm) but my dad sold the 100 a few years ago. Told me they only bought it is 1890 so it wasn't really part of the farm. It was the nicest ground.
We left the farm when I was three so I don't have the childhood memories other than occasional visits. And a renter burned the house in about 1980 that my great grandfather built. My dad bulldozed other buildings when he moved back for retirement in 1983. He also shoved all the old iron into a trench silo and had it covered up :sad: Then in his 90's he started getting nostalgic. But it is still hard.
Thanks, I hope to get some more hammers finished soon. I've had several takers but only the one on GJ. Mine has already come in handy tapping in bearing races.
tym
Andy: i'm not a fan of HARBOR FRIEGHT brand or imported tools...
Speaking of HF, what is with the banners they always hang over the front door? My local one has a new banner ever week it seems.
"Liquidation"
"Parking Lot Sale"
"Fire Sale" or some such
Or the latest from this week: "Disposal Notice." I kid you not. What the heck? :dunno:
dlcwent
Member Emeritus
coastal maine
Sorry about your search party. The Maine woods are vast.
I think you need a bigger generator.:willy_nil
Nice try with Cuda. But because she's such a sweetie, I'll bet you'll get a picture.:dunno:
I have every intention to come visit you. It's just a matter of when.
Ajustable
Niagara
hi andy
i have been following your shenanigans since the broom threads. Always a treat to sign in and read your posts. Thought I'd comment on the generator since we had a PTO 20kw model on our farm. Before we bought it the power would go out quite regular. After our purchase, we never needed it, always had power. That is called insurance I guess.
Keep up the great work. Chris
O
oldironfarmer
Terlton, Oklahoma
"Liquidation"
"Parking Lot Sale"
I like "Everything Must Go". If it were me, I would not sell all that stuff.:willy_nil
What do they do when they run out?:willy_nil:willy_nil
The Maine woods are vast, and my friends are half vast.:willy_nil
Go figure.
The generator is what my dad thought he needed. And he had two large ground source heat pumps. It has 95 hours on it and hasn't run in several years. Oil is clean, but it was on LP so no surprise. Four cylinder Ford 152 cu in.
Well, she has not sent me an address for her free broom:sad:
I'll just sit and wait until you show up:sad::sad:
hi andy
I always thought I'd get a PTO powered generator since I always have a couple of tractors ready to go. But never did. My dad has a nice automatic transfer switch set up which I thought about taking but it's a lot of work to remove one and may save the new owner some money if they buy a generator. We figured the 14 year old generator was not a big inducement to buyers, most people don't trust old equipment.
Our electricity has become more reliable over the years. But with my wife being disabled I always keep a portable generator around for safety. If I think this one will run the whole house I'll put in a manual transfer switch out at the pole where the meter is.
Thanks for coming in to sit for a spell!!
madoc1
spicewood, tx
i want to say i agree the best part of your farm sale is the getting along with your brother and sister. when we sold my folks farm it did not turn out so well. our brother does not talk with my sister and i unless prompted or there is a problem with a mutual investment.
tapping bearings? what are you rebuilding? a motor for jb?:lol_hitti
jim
jbmatth
Northern Ok.
jim
That was a low blow Jim. :) I wouldn't need him to rebuild an engine for me if I had my own bearing tapping hammer. :thumbup: Of course if I took him some Aluminum I'm sure he would help me make my own, I wonder where I could find some...
Andy, I'd be surprised if that generator wasn't enough to run your entire house in any weather condition. Good luck with the sell and I've been by your parent's place a few times in the past but never knew it was going to be someones property I didn't know at the time. :lol_hitti
JB
drivesitfar
TYM: i've got a huge Harbor Freight super store about 5 minutes from my house and i've only been there twice. one to buy a new weedburner and when i finally opened the box 2 years later cause i used salt for a while to kill my weeds the burner didn't work. i took it back and they gave me a new one and that didn't work either, but manager showed me it was operator error and how to start it and now i burn everything in site. i might buy something else there cause Costco sells about the same type of stuff that doesn't always last and some stuff does, but HF has crazy sales on some stuff and not surprised they constantly have a banner up at your store.
ANDY: how's the BULL these days while you are cutting trees and helping the family get the old farm ready to sell. if it doesn't sell maybe you can figure out a way to buy your brother and sister out for a fair price and deed it to the grand kids to keep it in the family. i think the DoBaker truck you are building will look fine in the driveway up there.
muffins??
cheers
madoc1
spicewood, tx
andy, you have been extra quiet. hope all is well. this is also a test of my usb keyboard you advised me on. i think it works. cheapest small one amazon is about $10 so i think it will be a good investment for my next trip. or should i spend $400 or so and get an ipad? we will see. but i will say no more trips to colo until i get my lung transplant or they jack up the oxy levels.:lol_hitti:sad:
good luck, jim
O
oldironfarmer
Terlton, Oklahoma
jim
My older brother always thought he should discipline me.:wtf:
We live two hours apart and have had a cordial but distant relationship. After our parents both died we have developed an unwritten and unspoken rule that we will get along and agree at all costs. As long as one held out we would not sell the farm. They key is agreeing with the majority and accepting the minority. I think we're all a bit surprised but very happy about it.
Tapping bearings was getting the the pump shaft and bearing back into the Massey power steering pump. JB likes stuff a little better than I do it.:willy_nil
JB
Well, can I put you down for one, JB? You have brought me enough aluminum for 100 of them.
I think the utility can tell me the highest amperage draw I've experienced. With a ground source heat pump heating and cooling are about the same and not too many amps.
muffins??
cheers
I've decided to try to buy out Harbor Freight. Deplete their inventory and they have to stop putting up the asinine banners.:thumbup:
I look before I buy and like what I've bought.
Bull is happy! My brother and sister would practically give their portion to any grandchild who might express an interest. But there are none. They all want to live in or near a big town.
Thanks for stopping in, guys!!
O
oldironfarmer
Terlton, Oklahoma
good luck, jim
I have to admit losing the photos took some wind out of my sails as far as posting goes. I have been busy on the Massey tractor and had three friends over yesterday.
Actually yesterday was a big day. I got a call early that the house we are renovating was being burglarized and my neighbor surprised them. He called me instead of the police, so I called 911 and hightailed it over there. They had tried to run him over, and then wrecked their truck trying to get out of the driveway (hooked front a-frame on power line guy wire) and took off running into the woods. I barely got finished with the reports in time to make it to Tulsa to have lunch with my old work group including three from Houston who later came out for a shop tour. By noon they had caught the crooks. Professionals with a winch under a cross bed tool box to pull the booty up into the truck. Mid-afternoon the realtor showed the house and made a sale, as is, except for repairing the A/C (thieves had cut one freon line) and replacing the hot water tank (thieves had cut it loose and were stealing it too). Called my A/C man about 3:00 and he went by, repaired then cut line, and had the house cooling by 5:00. Buyers want to start cleaning tomorrow so my handyman is fixing the water tank this evening. Then last night after the shop tour we had home grown steaks and fresh FFA corn on the cob.
What a roller coaster on the house! And now the buyers are willing to close tomorrow so I have to write up a deed and mortgage tonight. I'm going to like them, they got the utilities in their name today.:thumbup: Without my prompting!:thumbup::thumbup:
Lung transplant? That sounds serious. Best wishes on that issue. Is a lung transplant in the works?
Thanks for taking the time to visit.
O
oldironfarmer
Terlton, Oklahoma
Little update today. The gentleman who caught the thieves in the act is buying three lots from me. He had called last week to ask whether I wanted to buy some tools he acquired after they had been abandoned at his previous residence. He is a pretty trustworthy guy, bonded and works as a auto recovery contractor (repossess cars). I went and looked, appears most of the tools from a machinist. So I offered him a month's payment if he would deliver them. They came today.
A well worn Craftsman stacked unit, three small boxes, a full bucket and some wooden boxes.
I did not have time to look through the tools thoroughly, but did see a few things I don't have, like a 12" Mituoyo dial indicator. Good brand.
A tool box full of handyman type tools
And some good indicator holders.
The chest does not have a lot in it, but it will be fun looking.
O
oldironfarmer
Terlton, Oklahoma
Andy, done well as that's a great assortment..:thumbup:
Regards
Thank you!!:bowdown:
It will be a bit of a treasure hunt, and I was needing something to occupy the idle hours.
That's a busy day.
****** about the low life.
That CM stack looks like it will clean up well.
My only Saturday this week is 1.5 hours away :thumbup:
Wore me out. The low life's are everywhere. They will work harder trying to get away with doing nothing than it takes to do a job.
I must say I rather like having the repossession team on my development. They are extremely well armed and very aware of their surroundings. They jumped the realtor the first time he showed the house:lol_hitti Bounty hunters, I guess you call them. They work freelance to bring home the bacon.
I plan to clean out the boxes, repair (including the missing wheel) and repaint, kind of a spare time job.
Interesting how long it takes you blokes to get into a house. While it takes some time here, since I do my own financing and closings, the people that wanted to buy the house on Wednesday are signing my mortgage today, cleaning up today, and moving in this weekend. Best deterrent to vandalism is having an occupant. I have another house on the development the people moved in two weeks ago so we need to get their paperwork done. They are buying some agricultural land too and have been good to pay so I'm not too worried. I would rather have them in the house than it sitting empty. They are tattoo artists. I can get my tats in lieu of mortgage payments:rocker: I need to keep abreast of the trade. Of course, that is something you can't get off your chest. *** for tat, I think it's called. We haven't inked the deal yet, I just can't decide, and don't have one yet.
If I was a mortgage company I'd have too many rules to do things quickly and efficiently. And I'd never get tools for mortgage payments:rocker::rocker:
O
oldironfarmer
Terlton, Oklahoma
Managed to get out before breakfast this morning. My old compressor has a good 80 gallon tank, and my welding area and machine shop are about 150 feet away from the compressor by pipe. I haven't noticed any issues, but want to use the 80 gallon tank as an accumulator to provide more storage. The ideal place is up the stairs right over my south walk through door. It gets hot in the attic so this morning, with a gentle rain, it was time to move the tank. I had taken the compressor and motor off yesterday. The compressor is well worn and I can't find parts. I replaced the bearings in the motor and new springs in the starting switch a few years ago. Then the motor would throw sparks and lock up upon starting. It was 20 years old or more and I bit the bullet and bought a new Quincy. But it only has a 60 gallon tank.
Here's where the tank needs to go
I rigged a chainfall for a pipe slid on top of the truss bottom chord.
End of Part 1
drivesitfar
Andy: sorry to hear you are still having issues with your PB pictures and now again with GJ's album. like i mentioned i solved my issues by just downloading up to 7 pictures per post and even though they are not full size they will stay on GJ's site as long as GJ is alive.
wow those idiots actually ran their car/truck into your bounty hunter's truck/car? sorry to hear that even in your area the guys that think stealing is easier than working are around.
i know FARMS and FARMING WILL BE POPULAR AGAIN and some of us are now realizing that growing our own food not only tastes so much better we actually know it doesn't have some strange chemicals on it or some growth hormones.
we're actually looking at property, but we have to do more research on what the deer and other critters don't like or how to protect our garden or crops so we can actually eat some.
best of luck with the new compressor set up that you are modifying to hold more air. be careful taking that heavy tank up any stairs or do you have a lift for that.
