oldironfarmer
Andy: so do you do ZUMBA regularly so in case you need to run from that BULL you are able to??
i'm not sure there will be any video, but i'm pretty sure MANAGEMENT will let me take a few pictures of the bride and groom and maybe a few of them dancing too. not sure i'd want to clutter up the pictures with my mug though if that's ok.
our first and only dance rehearsal for the WEDDING CHAIR is this SUNDAY so i need to do a bit more tweaking before then. i'm almost thinking of building a prototype #2 out of wood cause MANAGEMENT doesn't like how noisy my aluminum one is.
keep checking on the WEDDING CHAIR THREAD and the link is in my sig line just above "I DO IT DADDY".
i'm guessing you are wishing me luck that i can actually pull this off since i'm neither a welder or fabricator?
cheers
Best not to try to run from a bull. Like running from a bear.
The wedding will be fine. You might try gluing some sound deadening material to the chair's flat spots. Heavy felt would be ideal, or hot rod shops have sound deadening material. It will not take much to quieten it down. You might also isolate the casters from the frame with a little rubber pad, or double sided tape or silicone gasket maker.
You've done great so far!
Nice picture.
My son's gate has a sign "with the high cost of ammunition do not expect a warning shot"
Best replacement for disc brakes was a guy that used pieces of wood as pads.
That's interesting! Never would try that. I guess it would get you a few miles but if you tried you could really "smoke 'em"
Andy, that is the first I ever heard of using the metal side of the pad for truing (kinda) a rotor. But it actually sounds feasible.You farm boys know all the tricks.
I am aware of the punch in the nose as my FIL always had oxen. But let me warn others that that method does not work on pigs. I actually broke a hoe handle in half over a boars nose after it bit my *** (thankfully I had a wallet that took the brunt of it) he just looked at me and snorted. I never put myself close enough to him to ever give him another chance to latch onto me.
You know most of what I say here is hopefully taken in the way it is intended (unintelligible babble)I never mean to offend.
Hopefully you will have a great weekend. I'm off to the races.![]()
I guess I wasn't clear. I use a new or used pad, turned the right way, to smooth up a rotor. It is surprising how the brake lining material will slick up a rotor as it gets ground away. The metal side would just continue to gall.
And don't call me a farm boy, I am a Registered Professional Engineer, Mechanical, much to the disdain of other P.E.'s I might add
The nose is a pig's weapon! They even dig with it. Cattle use the top of their head, with or without horns, and of course their hooves. But their nose is sensitive. Maybe worse than ours. And pigs are like us, omnivores, they eat meat, including other pigs and people if the opportunity arises.I never mean to offend either. It bears repeating often because lots of people are a little sensitive about what they have said and take poking fun the wrong way. And those people belong here too. They have the right to make a serious statement and not be ridiculed by those of us who don't have something very serious to say but enjoy saying it anyway.
After several enjoyable months, Dan could never offend me, even if he tried, I would just take it as well played sarcasm. Or poor choice of words
