I recently purchased a QR-325 ROC13 compressor. It builds pressure fine but leaks through the intake so I assumed the discharge valves were leaking.
The discharge valves look a little rough. Do I get these cleaned up with a sand blaster or is a wire brush in a parts cleaner sufficient? I think I mainly want to get rid of any loose bits that could interfere with the valve.
The valve disc and mating surface looks like it would clean up by lapping with some 400-600 grit sandpaper.
