Clear (acrylic) Sump Basin Cover?
roc_on_the_rocks
South central Indiana
Speaking about sump pumps, am I alone thinking that a clear sump basin cover is a good idea?
I need a new cover and there are lots of conventional composite covers around (e.g.: PlumbStar USA) but I'm considering buying or fabricating an acrylic cover. I don't have past experience with them, but it appears that Plexiglass is better for this intent than Polycarbonate (Lexan), but I'm all ears to the GJ advisory board.
Here's my sump basin:
4xdog
Santa Fe, NM
Polycarbonate’s big advantage is super-high impact strength. Its downside is that it weathers, and can be crazed in contact with water.
Acrylic’s big advantage is super-high weatherability and UV resistance. It has very low moisture absorption and sensitivity. There are impact-modified grades, such as some compounds promoted for use in automotive taillights for durability, but acrylic isn’t in the same class as polycarbonate for impact.
I’d probably go with acrylic, especially if your cover is exposed to sunlight or lives outside.
jack stand
Lakes Region Maine
I've never had a sump pump before....
Is this to visually monitor what's going on? If you remove the existing cover is it covered with condensation from an assumed temperature difference that would be impossible to see through.??
Is a cover/lid even necessary?
Crazyjake8493
Upstate NY
I don't see a reason to need to look in there constantly vs removing a solid cover on occasion. But if you really want to sit and observe I'd get a piece of 3/8" plexiglass and cut it to fit.
Fav Onefour
MN cold and hot
Is that a sump well for a drain tile system? Or is it just to handle condensate? I only see the drip line and small inlet with a plug.
In our area the newer sump wells for drainage have sealed covers to help prevent radon mitigation. I don't see a method for attaching a sealed cover.
I've seen clear covers on sealed systems and they usually have some condensation. I guess they can give you an idea of what is in the sump but you'll still need to remove the cover for a true picture.
I have a couple of drainage system sump wells with sealed covers that are under carpet. It wouldn't matter what type of lid was on those things.
I'm not sure of the goal you are trying to achieve? If you are worried about the pump failing there are other methods to monitor.
I use dual power float alarms in my sump wells. The batteries get checked when I do the smoke detectors. My brother has one at his cabin with phone notification and a camera pointed inside the well. That sump pump runs a lot year around. He keeps a spare pump ready at all times just in case the original gives out.
signcrafter
Our house we bought a few years ago came with a clear cover that someone had cut and then caulked to floor and pipes. Guessing it was done when they did the radon system. Sump pump went out the first year we bought the house so I removed that cover. It had become no longer see thru over the years so I just threw it away. Our sump pit is concrete so it also had the two pieces of concrete to cover the hole with a slot in the middle for the pipe to come up out of. So wouldn't have been able to see anything anyway. I left the concrete non sealed cover on for now and bought a radon monitor to see what the levels actually were. Plan is to get one of these in the near future to seal it back up, https://www.amazon.com/Original-Radon-Sump-Dome-Model/dp/B073V3RV5X/?tag=atomicindus08-20. It has a small window in it but other then checking to see if pit is full of water instead of being pumped out I see no reason to ever look down in there. If the water is rising from pump not working you will very shortly know anyway, and chances are you aren't checking it every few hours so you will notice the water on the floor before you notice anything wrong by looking in the window. If there is an issue that little sump pit will fill up pretty quickly. I have been looking into alarms for if the water raises higher then it should. Basically a second float set up higher then the sump pump float that will set off an alarm if water raises that high.
Skyman
Central Maryland
couch67
Ontario Canada
Id go with a much simpler solution and install a sump pit camera with NVR, and some ai to text you if there is a detected object or movement
but honestly, I did consider an acrylic cover (but never did it). I dont have a cover at all, and with it open I was getting mosquitos in the house around this time of year once the pit was full and not flowing any longer, and mosquito season just starting. I also liked the idea of covering it and being able to check if float switches are unobstructed and nothing fell in there (maaaybe if there was a cover on, I wouldnt need to worry about this lol)
I just forgot about it and its still open
BombShelter
State of Hockey
Acrylic or Polycarbonate, either will work but once you go over 1/4" it starts to get really expensive. Easy to cut with woodworking tools, just read up or you'll melt the plastic if you work too fast. You can get the material at your local plastic sheet supplier or US Plastic will hook you up.
I don't see any other lines except that condensate, as mentioned before, and the basket doesn't look perforated and everything looks pretty fresh, are you sure you need to upgrade?
jhelrey
MN
Use 3/4" plywood with a 6x6" plexiglass window. This is a great option if you have a radon system. You can remove the plexiglass window to reach in if needed.
