Clear coat
66 bigblock
Ma
Hi My 570 sq ' garage floor I was thinking of clear coating with Aliphatic Polyurethane . Also maybe a stain mix first of silver and charcoal to go with rear of garage where I installed black and white vinyl tiles .Any advice on this? Thanks John
LegacyIndustrial
deerfield, IL
Prime before you apply that urethane.
Armorpoxy
Don’t use a urethane on a floor without epoxy under it. We offer these in clear but any epoxy under a clear topcoat could yellow.
A better clear choice would be our clear SPGX one part polyurea since they can’t yellow.
66 bigblock
Ma
Hi was thinking of a stain combo of light gray and charcoal or clean floor, acid etch then coat natural concrete with a clear gloss or semi gloss . Advice on this? What to use for stain idea or the clear finish ?Thanks John
Armorpoxy
Any acetone type stain will work well, then use the SPGX as the clear protective topcoat.
LegacyIndustrial
deerfield, IL
John our DeltaDye is a water-based stain and is a great choice.
Email me if you need help choosing a sealer.
Good luck.
66 bigblock
Ma
Hi Scotty I watched your Delta Dye video that is what I was looking for in a stained finish.What colors did they use ? What sealer would I use over it SEC or ? Thanks John
LegacyIndustrial
deerfield, IL
The reddish/orange floor was Amber & RedOak, the other was silver mixed with lead and navy as the accent.
SEC is great.
