Clear epoxy?
Burgerkong
Markham, Ontario, Canada
I want to preserve the natural concrete look, have a new house that just closed so I get to work with virgin concrete. I understand polishing it to a smooth finish is extremely hard to do for a diyer, I was just planning on renting a grinder and going over the pad roughly then densifying it.
However, can I put clear epoxy down? Is there such a thing? Most places only sell coloured kits.
Thanks!
onetechyguy
I did a good sealer over mine but want to do epoxy now
KPSquared
Wetaskiwin, Alberta, Canada
This exact thing is currently being discussed in a few threads.
I'm planning on using products from Legacy Industrial. They have a clear Epoxy base that you follow up with a Urethane sealer.
CLICK HERE!
That's the package they just added to the site, I'm going to use an acid dye on mine first.
Here's one thread using this stuff from Legacy: http://www.garagejournal.com/forum/showthread.php?t=138832
And you're close enough to the border to run down and save on shipping. . .
AlphaGarage
Every Garage, AnyTown, USA
We do offer BondTite 1101. Usually it's used as a primer, but it also works as a clear topcoat - although not with the full strength that LiquaTile offers. BondTite can also be covered with EnduraShield 2254 for additional UV stability and abrasion resistance.
It will give the floor the "wet" gloss look.
jhutch
Kansas City
Your concrete looks fairly smooth at this point. You typically need to rough concrete up to install most epoxies. Clearing the floor alone will leave those scratches fairly visible. If it is sealed you'd need to remove it prior to epoxy also.
I can't tell if it's sealed or not at this time. A good sealer may be a better bet than a peeling epoxy a few months or years down the road. Acrylic sealers can be re-touched up if you do get chemical or abrasion damage.
There are matte finishes available in most sealers as well.
Hope that helps!
