Clever/compact bicycle storage?
Flargen
San Antonio, TX
I know there's little to be done to reduce the storage footprint of bicycles (especially in the era of these effing 29'ers), but I'm really at a loss regarding how to store 3 bicycles in my 8' ceiling garage efficiently. The ceilings are too low to hang them all overhead by both wheels, and my goal is to be able to still park 2 cars in the garage and be able to walk around them. Those swing-up ceiling storage systems are pretty much out of the question as well due to the lighting I've installed (LED housings on 4' centers).
Garage is a 20'x20'x8' attached garage with a ~6'x11' extension off the back wall. Said extension is currently slated to be used for a large U-shaped work bench (eventually hosting a benchtop mill and small lathe as well), so I'd rather not put the bikes back there.
The best idea I've come up with thus far is to hang them vertically at a 45° angle to the wall, starting in the corner closest to the 16'x7' garage door (since the space between the overhead tracks and wall is pretty much dead space anyway).
Anyone care to share their solutions?
rzims
Grass Valley, CA
I have all mine hung on hooks by their front wheel, which is not compact at all.
I found this image though where they pivot to the side once they are hung...
MrSurly
East Texas
Let's talk about what's *above* the garage. Attic? What pitch is the roof? I ask because there are ways to utilize some of that space, ceiling modification involved, of course.
DGersic
DeKalb, IL
Short term, not much. Long term, pull the pedals off and rotate the handlebars 90* to make the whole thing as thin as possible.
CJ7VFR
Central New Jersey
PRESS them onto the ceiling.
Lift them up to hooks that hook on to the front and rear wheel.
They're hanging upside down.
Now you hook a pulley to the ceiling,
Put the hook on the side of the stem
Lift it to the ceiling.
It's now 'laying' on the ceiling.
This almost exactly what I did with my bike when I lived in my townhouse!
The only difference is that instead of a pulley system to rotate the bike up to lay flat against the ceiling, I was able to push the bike up by hand and use a third hook and a bungi cord around the seat stem to hold it up.
It worked flawlessly for years! Now that I am in my new house, where the ceilings in the garage are much higher, I am going to use the two hooks and the pulley method.
As a matter of fact, I just bought two pulley systems about three months ago for our two bikes for this exact reason!
Jim
jonshonda
Wisconsin
I made my own version out of 2x4's and some angle iron. But it works slick.
CJ7VFR
Central New Jersey
Nice. You did an excellent job on the brackets!
But let me ask. You're not married are you?
I don't know any married man whose wife would let them put their bikes right by the front door like that.
Jim
jonshonda
Wisconsin
Jim
haha! Its a stock photo from the company Dahanger...they make the brackets.
While I don't have bikes by the front door, I do have my Santa Cruz Tallboy mountain bike hanging over our headboard! :bowdown:
carterbeauford
NW PA
Jim
almost got divorced over a Marin 29ER.
glad I kept it, I never get sick of looking at that rear triangle.
CarsonConcepts
North East, MD
Something along the lines of this would put them on their side up against the ceiling.
jwh
Rochester NY
I've got an older version of this from Harbor Freight.
Works well to get 2 off the floor, should work for 3.
Item#61231
John
Mecha
Volunteer State
What I made for myself. Hooks screwed into 2x4's 2 ft apart with 2 ft offseting between bikes.
F
Flargen
San Antonio, TX
Thanks for the tips - unfortunately, ceiling storage isn't an option with my lighting and air conditioning setup:
Seems like I either need to re-evaluate my bench plans in the rear extension, or finally commit to building a damn shed (which is long overdue).
rslaback
Westcentral Wisconsin
Do your trusses run with or perpendicular to the lights?
ProGun3400
Will County, Illinois
Keep the bench plans & rear extension. Build the shed, move the yard tools, lawn mower, bikes, etc to the shed. If you want to get creative, build a loft in the shed. I have a Suncast shed in a back corner of the yard that I built a loft in. I store pool pump/filter, hoses, ladder, patio umbrellas, pool accessories, etc off the floor. The shed floor is where patio furniture, yard tools, etc get stored for the winter. Problem solved....:thumbup:
PCMusicGuy
Houston, TX
I am in a similar situation, only my garage is even smaller. Roughly 18 x 18 with nearly 8 foot ceilings. I have a XL frame 29er as well. The attic space above the garage was deep enough on one side so I made some bicycle cubbyholes. I framed up the box in the attic, cut the hole in the ceiling (between the joists) and I am working on finishing the interior.
The pulleys are already mounted and work well with some 3/8" rope. The idea is to pull the bike up by the rear wheel. Since the the handlebars are wider than the space between joists, the grips will touch the ceiling. The front tire will be pulled off and hung on the wall.
The last thing I need to sort out is how to keep the bicycle in the correct orientation while pulling it up with the rope. I'm leaning towards making a tire/wheel sled with my 3D printer and using some DIN rail as the guide. That would keep the whole setup very compact, and more importantly, close to the wall. The current plan with just be to use some rope cleats/ties to secure it.
