cory58
I'm building an 80 sf climate-controlled room in my new garage. I'll be using it as an alternative to renting a climate-controlled storage unit. My plan was to put a window unit with heat through the exterior wall of the garage.
I started researching window units and haven't found one smaller than 7,500 BTU that has heat. That size heat/cool unit will cost almost 3x as much as a cool only unit needed for that size space.
Any advice on options for heating? Is there a "safe" space heater option? The garage is off-site and no one is at the property 90+% of the time. In case it helps, I'm in Charlotte, NC, so winters are not bad, and the ceiling height in the room will be approx 7.5 feet.
Thanks, Cory
Thanks, Cory
