Skyman
Here's our situation:
Multiple downspouts from a complex roof, and from an under-the-deck drainage system, are all feeding into underground plumbing. All or nearly all of these are clogged, causing backwash geysers where the downspouts enter the below-ground stuff. I don't know, and haven't so far been able to figure out, where any of this plumbing is daylighted. I also know nothing about the composition of most of the underground plumbing - whether it's perforated flex tubing, or ??? I can only see the verticals that the downspouts feed into, and their composition varies. Worse, some of it is running under what I'm sure was a rather expensively-installed paver-type patio in the rear, and walkway in the front, plus one that might be running under our asphalt driveway (I don't know where it goes). All of this plumbing and hardscaping was done on the previous owners' watch. I've reached out to him with a few unrelated, simple queries but received no response, so helpful information is unlikely to be forthcoming from him about this mess if I bother to ask. And he wasn't a DIY guy, so I'm not confident he'd have much to offer about it anyway.
I burned all of this past Saturday morning trying to clear one of the clogs, sucking at least a gallon of top soil out, then hitting a lot of tree roots with a plumber's snake. No joy was gained, as the clog persists. I presume the roots from a nearby River Birch have infiltrated this pipe in a big way, and I think the sensible path forward will be to abandon most of this pipe, and probably do the same with all of the others that are clogged (or possibly collapsed) below ground. I can foresee excavation in my near-term future, to replace many segments of the blocked system, and abandoning the remainder.
The main question all of this leads to is how best to daylight the downhill side of these pipes, which I likely would be fabricating with PVC. There's no hard surface onto which to dump the outflow, so it's gonna have to exit onto the lawn somehow -- ideally in such a way that doesn't create an erosion problem, a tripping or mowing hazard, or an ankle-breaking crater. The entire lawn slopes gradually away from the house with not much grade to it, but with enough slope to prevent pooling. At my previous home, I piped all of the downspouts underground in PVC, but there I had a hard surface onto which to dump the outflow. No similar opportunity exists here.
Any and all suggestions and advice will be gratefully accepted.
TIA
TIA
