Hello All,
These are really cool forums full of good stuff!
I have just bought a Condo That was built in 1992.
The garages are housed 4 to a building.
Each garage has 2 lights, 1 light switch, 2 wall outlets and one ceiling outlet for the garage door opener. On the outside of this building the are 4 lights and one GFCI outlet.
I am at one end of the garages and a panel with a a/c style direct pull disconnect is at the other end. Pull the disconnect and there are three 20 amp fuses on the end of it.
The garage owner at the end with the panel will not let me look at the wiring in his garage. the two in between his and mine seem to be wired the same.
On the side of my garage that is connected to my neighbor, I have 4 romex 12/2 lines coming in.
1 line goes to the outside light
1 line goes to the 1st wall outlet
1 line goes to the light switch( note there is only one line hooked up in the switch box but at the top of the wall there is another romex line coming out and going to the first light)
1 line goes to the first light.
at the first light:
1 romex from the hole in the wall
1 romex from the light switch (?)
1 romex going to the ceiling outlet
1 romex going to the 2nd light
next in the line: the ceiling outlet( for the garage door opener)
1 romex coming in from the 1st light
1 romex going out to the 2nd light
at the 2nd light:
1 romex coming in from the 2nd light
1 romex from the ceiling outlet.
the 2nd wall outlet is on the back wall and is drywalled up I cannot find where the romex is coming from , not the ceiling,
the fall wall that is not connected to a neighbor is where I am putting a work bench. I am installing to outlets and a light switch.
I am installing 4 flourescent lights ( 3 bulbs each ) in the ceiling.
I want to operate the left and right side of the garage lighting seperately.
I just do not know what is on what circuit.
Could all the outlets on the back wall be on a circuit and all the lights and the ceiling outlet be on a circuit and the outside lights on a circuit?
Any Ideas???
Thank You,
at the first light:
at the 2nd light:
Any Ideas???
Thank You,
