Clutch head screwdrivers
64C10
Globe, Az
Does anyone know of where one can source a decent clutch head screwdriver anymore? I bought the CTA set and am not too happy with their total lack of hardness (just rounded one off on a Holley metering plate).
I found some 1/4” bits, but would like a good set of dedicated drivers as well. Anyone know of a source?
Wrench97
Southeastern Pa
I don't believe Snap On makes them any longer but they were the best back in the 70's when I was using then all the time on the P series step vans.
Wilde use to make a decent set too but I don't any of them around either.
cgrutt
I've got a MAC P993A no idea if they still make them though.
cmaple
Mt. Home, AR.
I've been buying up clutch head drivers at yard sales and flea markets for a few years, lots of Stanley's, Ace and a nice set of wood handled Macs
64C10
Globe, Az
All I ever find used are rounded off 3/16”.
I did however find that Napa is producing them under the Carlisle badge, so order sent and fingers crossed. I absolutely loathe the “ergonomic” handles, but for as often as I get into carburetors or steering columns, I think I can live with it.
64C10
Globe, Az
90% I’ve come across from yard sales/flea markets have been Craftsman in varying stages of abuse/decay.
I had a really cool 5/32 driver that I came across at a flea market, full size handle with a little maybe 1” shank - marked as a promo for something or another auto parts. Someone borrowed it and it was never seen again.
driftpin
I bought a set of four to work on a Tri-Five Chevy, from one of the Tri-Five parts suppliers. They fit the dashboard, the fuel filler pipes, the hood reinforcement straps, and whatever else. I think it was Eckler's, but now out of stock.
Summit has a set:
NoahG
Detroit, MI
What size do you need? They’re plentiful in older Metro Detroit hardware stores. I see a LOT of old Stanley stock.
64C10
Globe, Az
I’ve got the Carlyles ordered, and the Summit Racing set (curious to see if there’s a WF marking on those).
Thank you though!
Kscardsfan
The Little Apple
I have a Carlyle that I have had good luck with, like everyone else said I just buy them at estate sales. Very few people know what they are or what to use them for. Last I knew, Snap-On was making them as sockets at least.
64C10
Globe, Az
I’ve found them as bits and sockets, mainly want the dedicated drivers for the hot rod toolbox (less to hunt through) and the tight quarters of the C10’s steering column.
PFSard
Mesa, AZ
* Any ideas how many sizes of clutch drivers there are?
* I bought a pouch with five Indestro Super drivers at an Estate Sale many moons ago. Lists part numbers on handles 4640 through 4644. Does not indicate the sizes.
CoogarXR
My Xcelite drivers cover 6 sizes in the G-style clutch:
G5166 - 5/16"
G146 - 1/4"
G3164 - 3/16"
G5324 - 5/32"
G183 - 1/8"
G3324 - 3/32"
There are A-style clutch too. I think I have 4 of those, but I don't have the sizes handy.
A Style looks like this:
G Style looks like this:
64C10
Globe, Az
I’m really not sure. I’ve got some old 50’s and 60’s hardware catalogs at the house that may shed some light on it.
Wrench97
Southeastern Pa
I have 6 of the G style in a snap on set and 5 of the A style in a Mac set.
And a few repeats of G style in craftsman and stanley that are mostly worn out.
Indestro clutch-head drivers and bits 1971 Indestro catalog No. 55
* I don't recall whether that Holley metering plate uses the 3/16" or the 1/4" size. I had only the bit for years, because that was the only thing I ever used those for. This is a full set in a custom roll-up that was made for me. The individual drivers show up on ebay quite frequently. Full sets are pretty rare.
64C10
Globe, Az
My 4160 screws are 5/32”
^ Sounds right. I remember they were very small. I only ever used that one size working on Holley four-barrels. Fortunately there weren't a lot of them (we weren't a Holley W.D. so most all "warranty" stuff went back to a distributor.)
woody 73
The Great State Up North
Some more info for anyone interested.
unslow1
Illinois
I have some proper clutch head screwdrivers. Then I have a few made from sacrificial flat heads. They seem to work about as well.
NoahG
Detroit, MI
An example in one of my usual spots today. I’d say I see 5/32” and 3/16” most often. I have no idea what sizes are actually common and in use in the word.
ecotec
Those are the only two that I have.
driftpin
Old Craftsman circular tip file, made of red plastic, outer ring and inner ring, and a clear plastic cover you turn to line-up the hole in it with the tip you need to access. It had at least two clutch head tips in it. The 'axle' screw/nut is an owner-added piece. I should trim the screw and throw-on an acorn nut for added 'high-zoot factor.'
Bought new, this is probably 45+ years old.
Craftsman screwdriver tip storage.02.pngCraftsman screwdriver tip storage.01.jpg
^ I have been using an Asian-made knock-off of that same "spinner" for over twenty years now. Mine didn't have clutch-heads in it: it was a mix of slotted/phillips/hex/torx bits with a few "nut drivers". Was my "go to" until I bought a big Vessel kit with more bits.
