kf4zht
- Location
- Ball Ground, GA
- Price
- 500
These are not getting used, time to pass them on:
9x20 Lathe - Had a Northern Tool sticker, dated early 90s. Same as the grizzly G4000. Runs fine, needs some of the gears, a bushing to get the autofeed to work and some cleaning on the tailstock. Switch works but needs a new knob. Extra belts included. $450 Local Pickup Only
MaxNC 10 Mini Mill - PO converted from proprietary system to Probotix system. Runs with LinuxCNC or Mach3, I can give you config files for either. Up and running now, will include a dozen or so toolholders and a pile of small end mills. Computer not included but anything that will run Mach3 and has a parallel port will work. $500, Local Pickup Only
Closed Loop CNC Servos/Drivers - Came off MaxNC, similar to the package they sell. Drivers are from JR Kerr, appear to be the previous version. Serial input. Also have a very non-ul approved 48v supply for it. I have not used this, but was told it works. $200 + shipping (dependent if you want the power supply)
Stuff if located in Ball Ground, GA (30107). I can meet around north atlanta, but if you want to demo the CNC you probably need to come to me. Will entertain trade offers on guns, ammo, table saw, wood band saw, benchtop or larger mill
