goldie lox
- Joined
- Feb 12, 2015
- Messages
- 142
Interested in getting one for personal use, who has one and what one do you recommend, remember home personal use so no 20k tables
Hi goldie lox, I was looking into the same thing and found you have more consumables (cost) with a plasma table. Look at a water jet, less consumables (cost), and able to work with a lot more materials i.e. steel, wood, plastics, glass, and the list goes on.
rngr1
Maybe I'm wrong, but I'm pretty sure comparably sized waterjets are MUCH more expensive than CNC plasma...WAZER was a tabletop size waterjet on Kickstarter and I think they cost like $5-6k.
Plus waterjet consumables are no joke. It's not just water, there is an abrasive consumable and a carbide nozzle consumable as well. Plus you have a high pressure pump that I'm sure will have some maintenance associated with it. With plasma, you just need a big/high power air supply and torch consumables.
Absolutely waterjet would be awesome! Can cut nearly anything (and is actually a preferred method for composites and hardened materials, for example), but it is seriously expensive as far as I know.
Cheapest waterjet ive seen is 80k and that supplier i wouldnt buy their plasma table either.
