Coats 5065e wiring help
Jsullenger
TN
I purchased a used coats 5065e machine but when I go to spin the turn table it pops the breaker..I was told it needed a new forward/reverse switch which I replaced and wired it the same as the old one but I am not sure it is wired correctly can anyone help me with a picture or wire color to switch numbers any help would be appreciated
Michael86
you probably figured it out. But if not, do you have an image of yours? Mine is a 5060ex so just want to make sure it's the same or that you still need the help before I go around and do that
