Hi all,
Had a question about a Coats 60X tire changing that's not clamping well. I changed the clamping pedal valve seals but was immediately skeptical that that was the issue because the original orings looked good when they came out. Anything else to check? Also is it typical a lot of air to go out of the exhaust ports when the clamping is activated? The bead breaker also exhausts a lot when activated. I'm not very familiar with these machines in general.
Thank you!
Thank you!
