I've been trying to avoid conduit like the plague but I think it may finally be time.
We just bought a disaster ski/vacation cabin type thing. It's 1500sq/ft including the 1-car attached garage. Technically we bought it as-is and technically the CO (occupancy cert) is revoked or suspended by AHJ. It's a little bit of a grey area though... AHJ has been very "accommodating" and "flexible" with our "fix prior homeowner mistakes" plan. (almost too accommodating and too flexible, it's weird)
We thought the house was in a little better condition than it is. I recently flipped --well not flipped, I fixed up our home (total gut/reno) that we currently live in and I fixed up a home two blocks over that we still own and a family member lives there. We somewhat bought this place sight-unseen. (never did a walkthrough but had detailed photos) I thought the place was in a little better condition than its current state. I'm feeling old and tired. This was supposed to be a nice little ski cabin on a lake that we could use year round (and I don't want to deal with conduit). It's basically a borderline condemned disaster that probably needs to be put into a dumpster. (and I still don't want to deal with conduit)
It's a 1-car garage attached to a tiny little house. I'm not trying to compete with Jay Leno's garage. Short-term I need to get the space functional enough that I have lights and power. I want to grab a couple free kitchen/dining room tables off Craigslist to use as workbenches and I have an old 900-pound 12" radial arm saw I'll throw up against a wall. (I'm old, and old-school, I like my radial arm saws)
Longer-term, once the home has a CO and we can legally stay there --I envision the garage as a giant mudroom. Back the car into the driveway, raise the garage door and have the kids unpack and take their clothes off: so I don't sound like a pedo... I mean take off wet/muddy/snowy clothes, hang up ski stuff, unpack and lay out their **** so it can dry for the next morning, etc. At same time I'd like the garage to be an open and finished-ish (inviting) space so maybe one day if the stars and moon are all aligned, wife & I can get away for a night/weekend and park a car in there.
I don't really want conduit on the walls because I want it to feel like a room inside the house. Also, I can 10,000% guarantee that if there is conduit running up the walls the kids will lean their (wet/icy) skis against it --and that's not really what conduit is meant for... The garage will be insulated properly. It will essentially be an extension of the house (except common firewall prevents that). The washer & dryer are out there --it's a weird setup with very thick common wall/firewall between house and attached garage, DWV, septic dump, plumbing, hvac, electrical chase, etc. all in that wall as if it were an after-thought, or maybe as if it were a house designed on a slab then they threw a basement in last-minute? Either way, the garage will be a conditioned space and I'd like it to feel like it is part of the home, not a garage.
My plan was/is to leave the (technically rafter ties and collar ties) exposed but finish/drywall the underside of the roof deck and the walls. For the nm-b/romex up higher than eight feet, I'll case it in something (accessible) like old barnwood veneer or I'll antique some 1/4" finish ply and figure something out.
Yes, I suppose that I could case and cover conduit too, except I already own the wire and like I said, I am willing to bet a year's worth of my salary that my (wonderful) children will use conduit as a leaning post for their wet/snowy/icy ski and outside ****.
There is enough extra wire in the structure (runs are all crazy long) to wire three houses and I have half spools of various /2 and /3 at home. (I'd be golden if you could use /4 with split phase). I'm trying to work within the framework of what I have. Personally I own benders but I've never really done proper/legit conduit. Is it a barrier to entry thing? I remember going from NPT to pvc and glue for plumbing stuff. That was an amazing transition. Is conduit that easy?
I just want to find an eloquent solution to transition (complaint) exposed nm-b into a stud cavity (behind drywall). I'm equally worried about my wife getting a snag or a pull in her clothes from the conduit as I am with my kids leaning stuff on the vertical runs.
OH --my first comment, avoiding conduit but it might be time: the idiot who installed the air handler and central AC was an idiot. I need to put down a pad, disconnect, wire it properly. Currently it is 10/2 just drilled through the wall and running direct to the compressor. So I have to deal with properly wiring a 2-ton residential AC unit: I think that means flex outdoor plastic (I know nothing about conduit)... something rated for water/weather >> disconnect box >> I assume rigid plastic/pvc because going from outside to inside >> some type of box so I can transition to metal because pvc conduit inside is ghetto... Which also means I don't think you can (or want to) strip NM-B and shove it through pipe because you probably want stranded and thhn doesn't have a W. No idea how to properly wire the outside part of an AC unit. Time to Google.
I also have to deal with the SE conductors between meter and panel. I want them in conduit. Have to ask AHJ about that. I'm comfortable pulling the meter and dicking around in the panel but unless PoCo disconnects I'm not sure I want to attempt swapping out service entrance wires. (I think I'm going to need new/longer (and maybe different type) if I run through conduit. Have to Google stuff like drip loops or how not to F-up your meter from water/weather. Meter is ghetto (drywall screws) to the house and overhead is below zoning minimum height. Need to sort a mast, weatherhead and whatever else. Also proper backer plate and flashing (over cedar shingles) for meter-box-to-house interface. This weekend will be fun fun...
Any tips, pointers or advice would be MUCH appreciated. NEC 2017. As far as I know, ahj has no requirements over ibc 2009 or nec 2017 other than a couple very clearly defined snow load items.
I know nothing about bringing power into a home or bringing power from inside to outside a home. Even website links would be a huge help. Thanks.
Sorry my posts/questions are so long. Hopefully I can learn enough that I'll be able to help and give back soon. Thanks again.
