Kaizen
In preparation for doing my garage subpanel I realized I really needed to clean up the house wiring so I don’t have any issues with inspection. In the process I ran across a situation and not sure if it’s an issue.
I have a few holes drilled in floor joists and each hole has several Rome’s wires going through each. The joists in question have radiant heat running through them for the floor above the water is about 120 degrees and the bay is insulated. Would this cause an issue with wire temp or is there any code that refers to this? Would this temp in addition to normal wire temp cause an issue? I can’t insulate the whole loop and not cover the wires.
