Falcon67
I imagine there's no issue, but I'll ask here while I try to get in touch with the local utility. We're (utility) is going to hook up a load center next the the meter to service a well pump and allow for a 70 amp shop feed. That part is all OK, no problem.
I can find locally a good GE 6 space main lug box - it's perfect. It's convertible with a 100 amp breaker and breaker tie down with just enough space for the other two breakers. Small and compact, copper buss, etc. The issue is there is no 1 1/4 knockout on the left side of the box for a ******. GE didn't put many knockouts on the the box at all. There is one 3/4" on the right side and a couple on the bottom. There are other models with knockouts, but none carried locally. Any code issue with punching a 1 1/4" hole in the side of this thing? I can find a Square D with knockouts on the side but it's not convertible (along with being 50% more expensive). There's nothing in the GE box to interfere with incoming #4 cable, so I can't really see an issue. The house uses a GE panel, so I'd like to stick with GE all around if possible. Thanks for any assistance.
