dave*99
Looking for code requirements for the following job. Replacing grounded receptacles. Currently the house has grounded receptacles. Boxes are steel. The grounding conductor is attached to the side wall of the boxes with a grounding clip. The receptacles are grounded through the yoke vai the 2 yoke screws.
Question: When replacing these (using new TR receptacles) is there any code requirement to connect the ground terminal on the receptacle yoke? Or can I continue to use the yoke screwed to grounded box as the sole ground. I'm looking for the NEC code answer to this.
The house was built in the 60's and I don't think the boxes are tapped for a grounding screw, so adding a ground pigtail may not be simple.
Dave
Dave
