r_olson_06
I Just got done installing an addition for an industrial facility and in this addition are 4-40hp material moving pumps for granular material. Went to call for an inspection and the inspector came out looked around for a while and said. "are these pumps listed" . The actual motor was NRTL listed and the Pressure switch was NRTL listed, The controller was NRTL listed. and so forth. Apparently this doesn't count? The motor and pump assembly must NRTL listed as a pumping unit and apparently this electrical not a mechanical problem. Could someone shed some light on this for me. I am familiar with the code and i understand that my equipment must be NRTL listed but the motor is and so is everything else my electrical connections are hooked to. Any help would be appreciated.
