tom-ky
Tried searching without much luck. Any suggestions on a decent scanner?
Depends on what you need to do. There's 3 classes of scan tools:
1. read and clear codes, view mode 6 data, freeze frame, smog check. no bidirectional controls or function tests. For this there are many options and they're cheap. I have a BlueDriver because I've got apple iphone and tablet. Android guys seem to like torque app with a supported OBDII interface
I'm in the same boat, needing to buy a code scanner. I'd like ABS and SRS functionality. Is this a decent buy for the home gamer? And has anyone used it on BMWs? I'm not too worried about using it on my Mercury, but the BMWs can be finicky I figure.
https://www.amazon.com/dp/B072XH9GLW/?tag=atomicindus08-20
That's similar to what I have. You can find Autel's coverage chart here: https://pro.auteltech.com/measurecar-1-1.html
when you start looking at ABS/SRS functions make sure you can find a coverage chart that shows your vehicle is supported for ABS/SRS
most DIY level units have pretty much the same coverage... if your vehicle isn't included in a coverage chart for one it's a high probability you'll have to look at very pricey pro level scanners or astronomically expensive dealer units
(I personally wouldn't mess with a $2,500 PCM using a $25 eBay cable but many report success so that is also a cheaper option).
Well luckily PCMs are not anywhere near $2,500![]()
Do you have a laptop? For BMW's there is no substitution for ista+. You can get this and a bimmergeeks cable for under $100. If you are paying them to install it for you make sure to also get ista-p.I'm in the same boat, needing to buy a code scanner. I'd like ABS and SRS functionality. Is this a decent buy for the home gamer? And has anyone used it on BMWs? I'm not too worried about using it on my Mercury, but the BMWs can be finicky I figure.
