Did you get the welder running ??
Not yet. I went to Lowes yesterday and got the outlet for the welder, wires to run from the outlet to the breaker panel and when I went to look for a breaker they didn't have one.
As per the website they had 5 of them in stock but we couldn't find one anywhere.
So I'm short a breaker right now. Then I need to get a welding helmet and some rods before I can test it.
But in the meantime, I had to repair a leaky bathroom faucet which turned out to be a simple rubber washer replacement.
Spent a little time staining/sealing the deck, with all of the rain it's hard to do it all in a weekend. So I spend an hour here and a hour there after work. Hopefully my wife will work on it now that school is out and she's home, she's a better painter then I am.
I'm also working on a spot for the firewood to be placed instead of just on the ground and out in the opening. I got the ground level enough and now need to dig the holes for the poles so i can build a little roof for it based on where the poles end up going. Then I'll place some extra retaining wall blocks I have stashed on the ground to keep the wood out of the dirt! Since I have some low spots and holes around the yard from pulling plants out of the ground I take my time to shift the dirt out so I can use it to fill the spots with. Apparently the previous owner used construction site leftover dirt cause the ground is full of metal bits, wire, and other trash so I want to remove all of that stuff before I dump the dirt in the holes.
But with the rain coming this afternoon I'll probably put my truck in the garage and do the oil change and get some stuff inside the garage done. Oh and order a breaker online for the welder so I will be sure to have one soon!
